1. Introduction to Pabbly Connect and AI Assistant
Pabbly Connect is essential for automating customer queries in the insurance industry. It allows businesses to create AI assistants that can handle repetitive questions efficiently.
In this tutorial, we will build a smart insurance FAQ bot using Pabbly Connect and WhatsApp. This assistant will answer queries regarding policy details, renewal dates, and claims, providing support 24/7.
2. Setting Up Your Pabbly Connect Account
To start building your AI assistant, first, access your Pabbly Connect account. If you don’t have an account, visit the Pabbly website and sign up for a free trial.
Once logged in, you will receive 100 free credits each month. Here’s how to set up:
  • Click on the “Sign Up Free” button to create an account.
  • For existing users, click on “Sign In” to access your dashboard.
  • Navigate to the “Pabbly Chatflow” section from the All Apps page.
After accessing your dashboard, you can start creating your AI assistant. Make sure to have your WhatsApp number ready for integration.
3. Creating Your AI Assistant in Pabbly Connect
In your Pabbly Chatflow dashboard, click on “Add Assistant” to start the process. You will need to name your AI assistant to identify it easily.
Follow these steps to configure your assistant:
  • Select the type of AI instruction from the dropdown menu.
  • Set the temperature for responses; a lower value gives focused answers while a higher one allows creativity.
  • Choose the AI model to use, such as GPT 5.4.
After setting these configurations, you will need to add your API key from OpenAI to enable the assistant to function correctly.
4. Uploading Knowledge Base for Your Assistant
To enhance your AI assistant’s capabilities, you must upload a comprehensive knowledge base file. This file contains all necessary information regarding your insurance services.
Here’s how to upload your knowledge base:
  • Download your knowledge base in PDF or TXT format.
  • In Pabbly Connect, click on “Add New File” to upload your document.
  • Select the uploaded file and insert it into your assistant.
This knowledge base acts as the brain of your assistant, enabling it to respond accurately to customer inquiries.
5. Testing Your AI Assistant with WhatsApp
Once your assistant is configured and the knowledge base is uploaded, it’s time to test it. You can trigger the assistant by sending a specific keyword via WhatsApp.
To test:
  • Send the keyword “policy” to your WhatsApp number.
  • Observe the welcome message and options provided by your AI assistant.
  • Interact with the assistant to check policy details and other queries.
If everything is set up correctly, your Pabbly Connect assistant will respond instantly, providing the necessary information.
Using Pabbly Connect, you can create an efficient AI insurance assistant that automates customer queries on WhatsApp. This setup enhances customer service and streamlines operations for businesses.
