To automate your SEO blog content with Pabbly Connect, start by accessing the platform. Visit the Pabbly Connect homepage by entering pabbly.com/connect in your browser. Here, you will find options to sign in or create a free account.
If you are a new user, click on “Sign Up Free” to get started. You will receive 100 free tasks each month to explore the software. Existing users can simply sign in to access their dashboard. Pabbly Connect is essential for integrating applications like Google for seamless automation.
Once logged into Pabbly Connect, you can create a new workflow. Click on “Create from Scratch” to begin. Pabbly Connect allows you to build custom workflows that automate tasks between various applications.
  • Select the trigger event, such as a scheduled time.
  • Choose the action event, like creating a post on Google Blogger.
  • Preview your workflow to ensure it meets your requirements.
After setting up the workflow, click “Approve and Create” to finalize it. This step confirms that Pabbly Connect is ready to automate your SEO blog content generation and publishing process.
3. Configuring the Trigger in Pabbly Connect
Next, you need to configure the trigger for your workflow. In Pabbly Connect, select the trigger event, which will initiate the automation. For this example, choose a scheduled trigger to run daily.
Set the time for the trigger, for instance, 1 PM daily. After configuring the trigger, click on “Save” to confirm the settings. This step ensures that Pabbly Connect will start the automation process as scheduled.
4. Adding AI Content Generation with Pabbly Connect
To generate SEO content, you will use an AI tool integrated with Pabbly Connect. Select the AI tool as your action application. Here, you can set up the parameters for content generation, such as the blog title and content type.
  • Input relevant prompts for the AI to generate content.
  • Select the AI model you prefer for content generation.
  • Save the settings to proceed.
After setting up the AI content generation, click “Save and Send Request” to initiate the process. Pabbly Connect will now generate the content as per your specifications.
5. Publishing Generated Content to Google Blogger
Finally, you will publish the generated content on Google Blogger using Pabbly Connect. Select Google Blogger as the action application and sign in with your Google account to grant access.
Map the title and content generated by the AI to the corresponding fields in Google Blogger. Choose the status of the post, such as “Live” or “Draft.” Click on “Save and Send Request” to publish your blog post. Pabbly Connect ensures that the content is successfully shared on your Google Blogger account.
By following this tutorial, you can effectively use Pabbly Connect to automate SEO blog content generation and publishing on Google Blogger. This integration streamlines the entire process, making it easier to manage your content.
