To start automating your Google Blogger posts, the first step is to access Pabbly Connect. You can do this by searching for pabbly.com/connect in your browser. Once there, you’ll find options for both new and existing users.
If you are a new user, click on “Sign Up for Free” to explore the software with 300 tasks every month. Existing users should simply sign in to their accounts. This initial setup is crucial for leveraging Pabbly Connect to streamline your blogging process.
After signing into Pabbly Connect, navigate to the dashboard where you can create a new workflow. Click on the “Access Now” button to reach the workflow creation area. Here, you can choose between various methods to create your workflow.
- Select “Quick Builder” for an easier setup.
- Define your trigger and action steps.
- Set the trigger to run daily at a specific time.
Once you’ve set up your trigger, you can proceed to configure the action steps that will automate the content generation for your Google Blogger posts.
In this section, you will set up the trigger for your workflow using Pabbly Connect. Choose the app and event options that determine how often the workflow will run. For this example, select “Every Day” and set the time to 8:00 AM.
Once configured, click on “Save” to finalize your trigger settings. You should see a message indicating that you have received a successful response, confirming that your trigger is scheduled correctly.
4. Generating Blog Content with Google Gemini
After setting up your trigger, the next step involves using Google Gemini to generate your blog post title and content. In Pabbly Connect, select Google Gemini as your action app and establish a new connection.
- Obtain your API key from Google AI Studio.
- Input a prompt for the title generation.
- Select the model type as Gemini 2.5 Flash.
Once you’ve set the parameters, click “Save and Send Test Request”. You will receive a successful response, indicating that the title has been generated by AI, which will be used in the next action step.
5. Posting the Generated Content on Google Blogger
The final step is to post the generated content to your Google Blogger account using Pabbly Connect. You’ll need to create another action step where you sign in with your Google account to allow Pabbly Connect access.
After connecting, select your blog ID and map the title and content generated by Google Gemini. Ensure that the status is set to live, and click “Save and Send Test Request”. A successful response will confirm that your new blog post has been published.
By utilizing Pabbly Connect, you can automate the process of generating and posting content to your Google Blogger account. This tutorial provides a straightforward approach to streamline your blogging efforts using AI tools like Google Gemini. Start automating your blog today for a more efficient workflow!
