To start automating your social media content creation, access Pabbly Connect by visiting pabbly.com. This platform allows you to connect multiple applications seamlessly.
Once on the Pabbly Connect landing page, you can sign up for a free account or log in if you’re an existing user. After logging in, click on the “Access Now” button to reach the dashboard.
In this step, you’ll create a workflow to automate your social media postings. Click on the “Create Workflow” button on the right side of the Pabbly Connect dashboard.
  • Type in your desired workflow name, such as “Daily Social Media Posts”.
  • Select a trigger app; in this case, choose Google Air Stud.
  • Set the trigger event to schedule daily posts.
After setting up the workflow, click on “Create Workflow” to proceed. This sets the foundation for your automation process.
3. Generating Content with Google Air Stud
Next, you’ll generate engaging content using Google Air Stud. This is where Pabbly Connect plays a crucial role in connecting Google Air Stud with your workflow.
In the workflow, add a new action step and select Google Air Stud as the application. Choose the action event to generate captions for your posts. Input your prompt, such as “Generate an engaging Facebook post caption for my skincare brand”. This prompt will guide the AI in generating relevant content.
  • Ensure you specify the model to be used for content generation.
  • Test the request to verify that the caption is generated successfully.
Once you receive the generated caption, you can proceed to the next step, which involves creating images based on the generated content.
4. Generating Images for Social Media Posts
After generating the captions, the next step is to create images using the same content. Pabbly Connect allows you to integrate another application for image generation.
Add another action step to your workflow, selecting Google Air Studio for image creation. Use the previously generated caption as input for the image generation process. This ensures that the image aligns perfectly with the content.
  • Map the caption response from Google Air Stud to the image generation step.
  • Choose the model for image generation, such as Nano or Pro.
Once the image is generated, you are ready to publish it on your desired social media platforms.
5. Publishing Posts on Social Media
The final step in your automation workflow is to publish the generated content on your social media pages. Again, Pabbly Connect facilitates this crucial integration.
Add a final action step to your workflow, selecting Facebook Pages as the app. Choose the action event to create a page photo post. Map the image URL and caption generated in the previous steps to the respective fields in the Facebook post.
  • Select the Facebook page where you want to publish the post.
  • Click “Save and Send Test Request” to verify the post creation.
Once confirmed, your automation setup is complete. Your posts will now be published daily at the scheduled time, ensuring consistent engagement with your audience.
This tutorial demonstrated how to automate social media content creation using Pabbly Connect, Google Air Stud, and other platforms. By following these steps, you can streamline your social media marketing efforts effectively.
