1. Setting Up Pabbly Connect for App Creation
To begin creating apps using Pabbly Connect, first access your Pabbly Studio account. Pabbly Connect serves as the integration platform that allows you to connect various applications seamlessly.
Once logged into your Pabbly Studio account, navigate to the settings section. Here, you will find the connection URL that you will use to link Pabbly Studio with Cloud AI or ChatGPT.
2. Connecting Cloud AI to Pabbly Connect
Next, you will connect Cloud AI to Pabbly Connect. Start by accessing your Cloud AI account and clicking on your profile icon. From there, select the settings option.
  • In the settings, go to the connectors section.
  • Click on the add button to create a new custom connector.
  • Name your connector, for example, “MCP for Pabbly Studio”.
After naming your connector, you will be prompted to enter the MCP server link provided by Pabbly Connect. Paste the URL and proceed to authenticate your connection, allowing all necessary permissions to finalize the setup.
3. Integrating ChatGPT with Pabbly Connect
To use ChatGPT with Pabbly Connect, access your ChatGPT account and navigate to the plugins section. Here, you will add a custom MCP server.
Follow these steps to complete the integration:
  • Click on the add button in the plugins section.
  • Name your plugin as “MCP for Pabbly Studio” and add the necessary connection details.
  • Enable the permissions required for the plugin to function properly.
After setting up the plugin, you can create prompts to test the connection and see how ChatGPT generates applications using the Pabbly Connect integration.
4. Creating Applications with Pabbly Connect
Once the integrations are in place, you can start creating applications. Using Pabbly Connect, you can send prompts to either Cloud AI or ChatGPT to generate apps like Snake Mania.
Simply provide a clear command, and the AI will respond with a link to the application created. This process is streamlined through Pabbly Connect, ensuring that your app is published directly to your Pabbly Studio account.
After receiving the app link, you can check your Pabbly Studio account to see the new app listed, confirming that the integration was successful and the app is now live.
5. Conclusion
In this tutorial, we explored how to create and publish apps using Pabbly Connect, integrating both ChatGPT and Cloud AI with Pabbly Studio. With Pabbly Connect, the entire process is seamless, requiring no coding knowledge.
Using the steps outlined, you can quickly set up your integrations and start building applications efficiently. Pabbly Connect truly simplifies the app creation process for users of all levels.
