1. Setting Up Pabbly Connect for Automated Reels
To create and post funny animated reels automatically, start by accessing Pabbly Connect. This powerful integration platform allows you to connect various applications seamlessly. First, visit the Pabbly website and log in or sign up for a free account to get started.
Once logged in, you can create a new workflow. This workflow will automate the process of taking your ideas from Google Sheets and posting them as animated reels on Instagram. With Pabbly Connect, you can effortlessly manage triggers and actions between different applications.
2. Configuring Google Sheets with Pabbly Connect
The next step involves setting up Google Sheets to capture your ideas. You will need to enter your creative story ideas into a designated spreadsheet. This is crucial for the automation process, as Pabbly Connect will monitor this sheet for new entries.
  • Create a new Google Sheet and name it appropriately.
  • Add your story ideas in the first column and specify the animation style in the second column.
  • Use the Pabled FBX add-on to link your Google Sheets with Pabbly Connect.
After setting up your Google Sheet, you will configure the Pabled FBX add-on to connect with Pabbly Connect. This will allow the automation to trigger whenever a new idea is added to the sheet.
3. Integrating Gemini AI for Video Creation
Now that your Google Sheets are set up, it’s time to integrate Gemini AI for video creation. This step is essential as it converts your text ideas into engaging animated reels. Using Pabbly Connect, you can set up a connection to Gemini AI.
In your Pabbly Connect workflow, select Gemini AI as the action app and choose the option for text-to-video generation. You will map the inputs from your Google Sheets, allowing Gemini AI to generate videos based on your story ideas.
Make sure to specify the style of animation you want, such as funny 3D animations. This customization is crucial to ensure that the generated content aligns with your vision.
4. Publishing the Animated Reels to Instagram
After generating the animated video, the next step is to publish it on Instagram. Using Pabbly Connect, you can automate this process as well. First, ensure you have your Instagram for Business account linked to Pabbly Connect.
  • Select the option to publish a video on Instagram.
  • Map the video URL generated by Gemini AI to the Instagram publishing action.
  • Add a caption generated by Gemini AI to your post.
Once you have mapped all the required fields, click on the test request button in Pabbly Connect. This will publish the video to your Instagram account automatically. You can verify the post by refreshing your Instagram feed.
5. Confirming and Updating the Process
Finally, to ensure everything is working smoothly, you need to update your Google Sheet to reflect that the reel has been created. This is where Pabbly Connect shines once again.
Select the Google Sheets action in your Pabbly Connect workflow and set it to update the status of your reel creation. This step ensures that you have a record of what has been posted and when.
Once the status is updated in your Google Sheet, you can easily track your content creation process. This final confirmation step completes the automation, allowing you to focus on generating more ideas while Pabbly Connect handles the posting.
By following these steps, you can automate the creation and posting of funny animated reels using Pabbly Connect, Gemini AI, and Google Sheets. This seamless integration allows you to focus on creativity while the automation takes care of the rest.
