To create Pinterest pins automatically, you first need to access Pabbly Connect. Start by searching for Pabbly.com in your browser, which will take you to the homepage of Pabbly Connect.
Once on the homepage, you will see options to sign up or log in. If you are a new user, click on “Sign Up for Free” to get started with 100 free tasks each month. Existing users can simply sign in to their accounts.
After signing in, navigate to the Pabbly Connect dashboard to create a new workflow. Click on “Create from Scratch” to build a workflow tailored to your needs.
  • Select the trigger event for your workflow.
  • Choose the action that should follow the trigger.
  • Ensure the workflow runs at a specific time each day.
For this automation, set the trigger to run every day at 12 PM. This will initiate the workflow to generate Pinterest pins automatically.
3. Integrating AI Tools with Pabbly Connect
Next, you need to integrate AI tools with Pabbly Connect to generate relevant content for your Pinterest pins. Use tools like Gemini for generating captions and images.
To start, select the AI tool you want to use and input the necessary API key. You can retrieve this key from your AI tool’s settings. Once you have the key, paste it into the designated field in Pabbly Connect.
  • Generate a pin caption using the AI tool.
  • Create a relevant image for the pin.
  • Ensure both elements are connected to your Pinterest account.
After setting up the AI tool, your workflow is now equipped to generate content for your Pinterest pins automatically.
4. Posting to Pinterest Using Pabbly Connect
With your AI tool integrated, it’s time to post your generated content to Pinterest using Pabbly Connect. This step involves creating a connection with your Pinterest account.
Click on “Connect with Pinterest” and follow the prompts to allow Pabbly Connect access to your Pinterest account. Once connected, select the board where you want to post your pins.
  • Map the generated image URL from the AI tool.
  • Add the description generated by the AI.
  • Finalize the title for your pin.
After filling in these details, click on “Save” to complete the posting process. Your new pin will be created and visible on your Pinterest account.
5. Conclusion
In this tutorial, we explored how to use Pabbly Connect to automate the creation of Pinterest pins by integrating AI tools. By following these steps, you can efficiently generate and post new pins daily, enhancing your Pinterest presence.
Utilizing Pabbly Connect simplifies the automation process, allowing you to focus on your content strategy while ensuring consistent posting.
