To create Facebook Reels, first, you need to access Pabbly Connect. Go to pabbly.com and navigate to the Pabbly Connect landing page.
If you are already a user, simply sign in. If not, sign up for free to get started. You will receive 100 tasks per month to create your automation setups.
2. Setting Up Google Sheets with Pabbly Connect
In this step, you will set up Google Sheets to trigger the creation of your Facebook Reel. The trigger will be a new or updated spreadsheet row in Google Sheets.
  • Open your Google Sheets and enter your story.
  • Install the Pabbly Connect Webhook add-on from the extensions menu.
  • Copy the webhook URL provided by Pabbly Connect and paste it into the add-on settings.
Once you submit the configuration, you will see a success message indicating that the webhook URL has been added. This setup allows new data entered into Google Sheets to trigger the automation process through Pabbly Connect.
3. Generating Captions Using Gemini
After setting up Google Sheets, the next step is to generate captions for your Facebook Reel using Gemini. Connect to the Gemini API through Pabbly Connect.
To do this, go to the Gemini API section, select “Add New Connection,” and provide your API key. You can generate this key from the Gemini playground section.
  • Write a prompt that describes your video idea.
  • Use mapping to dynamically insert the video idea captured from Google Sheets.
  • Test the connection to ensure the caption is generated correctly.
Once the connection is established, you will receive a response with the generated caption based on your video idea, facilitating the creation of your Facebook Reel via Pabbly Connect.
4. Creating the Facebook Reel
The final step involves creating your Facebook Reel using the generated caption and video content. Navigate to the connected section in Pabbly Connect, and select “Add New Connection” to connect with Facebook.
After logging into your Facebook account, select the page where you want to post the reel. Map the video URL you received from Gemini and the caption generated earlier.
  • Ensure the video URL and caption are correctly mapped.
  • Click “Save and Send” to post the reel.
  • Refresh your Facebook page to see the newly created reel.
With this setup, you can automatically create Facebook Reels using Pabbly Connect, Gemini, and Google Sheets, streamlining your content creation process.
In this tutorial, we explored how to create Facebook Reels using Pabbly Connect, integrating Google Sheets and Gemini effectively. This automation not only saves time but also enhances your content creation process.
