1. Access Pabbly Connect to Start Automation
To automate your Facebook posts using Gemini AI, first, you need to access Pabbly Connect. Go to Pabbly’s website and sign up for a free account if you’re a new user or log in if you already have an account.
Once you’re logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow that will automate the posting process to your Facebook page. This setup will significantly reduce the time spent on content creation.
To begin creating your workflow, select the option to create a new workflow in Pabbly Connect. You will be prompted to choose a trigger for your automation.
  • Select ‘Schedule’ as your trigger event.
  • Set the frequency to daily at a specific time.
  • Click on ‘Save’ to confirm your trigger settings.
This step ensures that your workflow will run automatically every day, generating new content for your Facebook page without manual intervention.
3. Integrate Gemini AI for Content Generation
Next, you’ll need to connect Gemini AI to Pabbly Connect for generating content. Select Gemini from the list of applications and choose the action event to generate content.
In this step, you will need to provide a prompt for Gemini AI. Specify the type of content you want it to create, such as a post for your skincare brand. After entering the prompt, click on ‘Save’ to proceed.
4. Generate an Image Using Gemini AI
After generating the content, the next step is to create a relevant image. Again, choose Gemini AI as the application and select the action event to generate an image.
  • Select the model you want to use for image generation.
  • Provide a prompt for the image that aligns with the content generated.
  • Click on ‘Save’ to confirm the image generation settings.
This integration with Pabbly Connect ensures that both the content and image are created seamlessly, ready for posting.
5. Share the Generated Content on Facebook
Finally, to share your generated content on Facebook, you need to set up a connection between Pabbly Connect and your Facebook page. Choose Facebook as the application and select the action event to create a post.
Map the content and image URLs generated in the previous steps to the respective fields in the Facebook action. After setting everything up, click on ‘Save’ to finalize your workflow. This will allow you to automatically post the generated content to your Facebook page daily.
By following these steps, you can easily automate Facebook posts using Gemini AI and Pabbly Connect. This integration saves time and ensures consistent content delivery for your brand.
