1. Setting Up Your Pabi Account
To begin integrating Enter with Pabi, you first need to set up your Pabi Connect account. Visit the official Pabi website and either sign in or create a new account. If you’re new, you can sign up for free and get access to 100 tasks every month.
Once logged in, navigate to the Pabi apps page. Here, select Pabi Connect to access the app dashboard where you can manage your workflows. This is crucial for creating the integration you need.
2. Creating Your Workflow in Pabi Connect
Creating your workflow is essential for connecting Enter with Pabi. Start by clicking on the “Create from Scratch” option. Name your workflow something descriptive, like “Create Contacts from Landing Page Leads in Minutes.” Select the appropriate folder for organization.
After creating the workflow, you’ll need to set up a trigger application. For this integration, choose Pabi Connect as your trigger application and select “Catch Webhook” as the trigger event. This step is vital as it starts your automation whenever a new form submission occurs.
  • Click on “Connect” to establish a connection.
  • Insert this URL into your form’s code to link it to Pabi.
After following these steps, test your connection to ensure it’s working properly. You should see a confirmation that the webhook is ready to capture responses.
3. Testing Your Connection and Capturing Data
Testing your connection is a critical step in the integration process with Pabi Connect. After setting up your webhook, refresh the page and submit a test form. Enter a name, email, and phone number to simulate a real submission.
Once submitted, check your workflow in Pabi Connect to see if the webhook has captured the response. You should see the details you entered, confirming that the connection is functioning correctly.
  • Ensure that the name, email, and phone number appear in your workflow.
  • If the data is captured, your integration is on the right track.
This successful test indicates that whenever a new form submission occurs, the data will be automatically sent to your workflow in Pabi.
4. Integrating Google Contacts with Pabi
Now that your webhook is set up, it’s time to integrate Google Contacts using Pabi Connect. In the action application, search for Google Contacts and select “Create Contact” as the action event.
Click on “Connect” to establish a connection with your Google account. Follow the prompts to allow Pabi access to your Google Contacts. This step is essential for automating the contact creation process.
  • Map the fields from your form submission to the relevant fields in Google Contacts.
  • Ensure you enter the first name and last name separately for accurate mapping.
After entering all necessary details, save the action step and perform a test to confirm that the contact is created in Google Contacts as intended.
To finalize your integration, ensure all mappings are correctly set up. Instead of manually entering data, utilize the mapping feature in Pabi Connect to dynamically pull in data from your form submissions.
Once you’ve mapped all necessary fields, click on “Save and Send Test Request” to verify that everything works smoothly. Check your Google Contacts to confirm that the new contact appears with the correct information.
  • Review the contact details in Google Contacts to ensure accuracy.
  • If successful, you’ve completed the integration!
This integration allows you to automatically create contacts from your form submissions, streamlining your workflow and saving time.
Integrating Enter with Pabi using Make can significantly enhance your workflow efficiency. By following these steps, you can automate the creation of Google Contacts from your form submissions, ensuring that no lead is missed. This seamless integration is a powerful tool for managing your contacts effectively.
