1. Accessing Pabbly Connect to Set Up Your Automation
To begin automating your blog creation, you need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect. This platform allows you to connect various applications seamlessly, enabling automation without coding skills.
Once on the workflow page, you will see options for signing in or signing up for free. If you are a new user, create an account to start your free trial. Existing users can simply sign in to access their dashboards.
2. Setting Up Google Sheets as a Trigger in Pabbly Connect
In this section, we will configure Google Sheets as the trigger application in Pabbly Connect. Select Google Sheets as your trigger app and choose the event “New or Updated Spreadsheet Row”. This will initiate the workflow whenever a new entry is added.
  • Select Google Sheets as your trigger application.
  • Choose the event “New or Updated Spreadsheet Row”.
  • Build the connection to Google Sheets by following the prompts.
After selecting the trigger, Pabbly Connect will provide a webhook URL. Copy this URL and add it to your Google Sheets using the Pabbly Connect Webhooks add-on. This integration allows the data from Google Sheets to be fetched automatically by Pabbly Connect.
3. Configuring the Webhook in Google Sheets
Next, we need to configure the webhook in Google Sheets. Go to the Extensions menu, select Add-ons, and then get add-ons to find Pabbly Connect Webhooks. Install it if you haven’t already.
Once installed, go back to Extensions, select Pabbly Connect Webhooks, and click on Initial Setup. Enter the webhook URL you copied earlier and specify the trigger column, which should be the last data column in your sheet.
  • Open Google Sheets and navigate to Extensions > Add-ons > Get add-ons.
  • Search for Pabbly Connect Webhooks and install it.
  • Go to Extensions > Pabbly Connect Webhooks > Initial Setup and paste the webhook URL.
After setting this up, send a test response to ensure that Pabbly Connect is receiving data from Google Sheets. This step is crucial for confirming that the integration is working correctly.
4. Generating Content Using OpenAI
With the trigger set up, we can now use OpenAI to generate content. Select OpenAI as your action application in Pabbly Connect and choose “Chat GPT” as the event. You will need to enter your OpenAI API key to establish the connection.
Once connected, select the AI model (e.g., GPT-5) and provide the prompt for content generation. Use the mapping feature in Pabbly Connect to input the title and description from the Google Sheets response dynamically.
  • Select OpenAI as the action application.
  • Choose the event “Chat GPT” and enter your API key.
  • Map the title and description fields from Google Sheets.
After mapping, click on “Save and Send Test Request”. OpenAI will generate the blog content based on the provided title and description, which will be sent back to Pabbly Connect.
5. Posting the Generated Content to Blogger
The final step is to post the generated content to your Google Blogger account. Select Google Blogger as the last action application in Pabbly Connect and choose the “Create a Post” event.
Connect your Google account and map the blog ID, title, and content from the OpenAI response. Set the post status to live, ensuring that the blog is published immediately.
  • Select Google Blogger as the action application.
  • Choose the event “Create a Post” and connect your Google account.
  • Map the blog ID, title, and content from the OpenAI response.
After setting this up, click on “Save and Send Test Request”. You should see a confirmation response indicating that your blog post has been created successfully. Refresh your Blogger account to see the new post live, demonstrating the power of Pabbly Connect in automating your blogging process.
In this tutorial, we explored how to automate blog creation using Pabbly Connect, Google Sheets, and OpenAI. By following these steps, you can streamline your blogging process and save valuable time. Start using Pabbly Connect today to enhance your productivity!
