1. Setting Up Pabbly Connect for WhatsApp Campaigns
To automate your WhatsApp campaigns, you need to set up Pabbly Connect. Start by visiting the Pabbly Connect website and creating an account. Once your account is active, you will gain access to the dashboard where you can initiate the integration process.
After logging in, you should ensure that your WhatsApp number is added to your Pabbly Chat Flow account. This is crucial for sending messages to your customers. If you need guidance on this, refer to the instructional video linked in the description.
2. Creating a WhatsApp Broadcast in Pabbly Chat Flow
To create a WhatsApp broadcast, navigate to the “Broadcast” section in the left menu of Pabbly Chat Flow. Here, you can select the type of broadcast you want to create. Choose “Campaign Broadcast” and name your campaign, for example, “Promotional Offers”.
  • Select the audience for your broadcast.
  • Create a new contact list or upload a CSV file with customer details.
  • Utilize the filtering options to exclude specific contacts.
After selecting your audience, you can proceed to the message type. You can either send a regular message or use a pre-approved message template. Using Pabbly Connect, you can ensure that your broadcast reaches the right customers effectively.
3. Importing Contacts from CSV in Pabbly Chat Flow
To import contacts into your broadcast, you can use a CSV file. If your customers are not already in Pabbly Chat Flow, select the option to upload a CSV file containing their details. This function simplifies the process of adding multiple contacts at once.
Ensure your CSV file is correctly formatted. Once you have your CSV ready, go to the contacts section, select “Add New Contact List”, and upload your file. Pabbly Connect will handle the integration, allowing you to manage your contacts seamlessly.
4. Sending Test Messages Using Pabbly Connect
Before launching your broadcast, it’s essential to send a test message. In the message setup, input your name and phone number to receive a preview of how the message will appear to your customers. This step ensures that everything is set up correctly.
Click on the “Send Test Message” button to verify the message format. This feature is invaluable as it allows you to confirm that the message sent through Pabbly Connect meets your expectations before the actual broadcast.
5. Scheduling Your WhatsApp Broadcast
Once you are satisfied with the test message, you can schedule your broadcast. Choose whether you want to send it immediately or at a later date. If scheduling, select the date and time for your broadcast to go live.
For instance, you can set it for October 1, 2026, at 11:00 AM. This feature allows businesses to plan their campaigns effectively, ensuring that messages are sent at optimal times. Pabbly Connect will automatically handle the sending process at the scheduled time.
Using Pabbly Connect to automate WhatsApp campaigns is a powerful way to engage with customers. By following these steps, you can efficiently create and manage your broadcasts, ensuring your promotional messages reach the right audience at the right time.
