1. Creating a WhatsApp Chatbot with Paby Chatflow
To create a WhatsApp chatbot, you will utilize Paby Chatflow. Start by visiting the Paby Chatflow website and signing up for an account. After logging in, ensure you add your WhatsApp number to your Paby Chatflow account.
Once you are on the dashboard, navigate to the left-hand menu and select the “Flows” option. This will take you to the flow builder page, where you can design your WhatsApp chatbot. The first step is to choose a trigger event for your chatbot.
2. Setting Up Trigger Events for Now and Paby Integration
In this section, you will set up the trigger event that initiates your WhatsApp chatbot. Choose the “Keyword Matches” trigger, which will activate when a specific keyword is entered by the user. For example, typing “hello” will start the chatbot.
- Select “Keyword Matches” from the trigger options.
- Enter the keyword that will start the interaction.
- Confirm the trigger setup to initiate the flow.
After setting up the trigger, you can begin building the chatbot flow using various message and action blocks. This allows for a dynamic interaction with users.
3. Building the Chatbot Flow with Paby and Now
Using Paby Chatflow, you can create a series of messages and actions that the chatbot will follow. Start by dragging and dropping message nodes to define the interaction. For instance, you can send a welcome message or an image when a user initiates the chat.
After sending the welcome message, you can add buttons for user interaction. For example, if a user clicks “Plan My Event,” the chatbot should provide a list of events. To do this, you will need to use the list node feature.
- Drag and drop a list node into the flow.
- Add sections and items to the list for available events.
- Ensure each item has a contact custom field for tracking user selections.
This structure allows you to capture user preferences effectively, enhancing the interaction quality.
4. Personalizing User Experience with Paby and Now
Personalization is key in chatbot interactions. In this step, you will utilize custom fields to store user selections. When a user selects an event, you can ask follow-up questions tailored to their choice.
For example, if a user selects a wedding event, you can prompt them for the date. This is done by using the “Ask Question” node, where you can include variables that reflect the user’s previous choices. This helps in creating a more engaging experience.
To implement this, follow these steps:
- Drag the “Ask Question” node into the flow after the user selects an event.
- Enter a personalized question such as “What date is your wedding?”
- Store the response in the relevant contact custom field.
This method ensures that the chatbot can provide a tailored response based on user inputs, enhancing overall satisfaction.
5. Finalizing Your WhatsApp Chatbot with Paby Chatflow
Once you have set up the entire flow, it’s time to finalize your WhatsApp chatbot. You will need to review all the messages, actions, and buttons to ensure everything works seamlessly. This includes confirming that all buttons redirect users to the correct sections.
After finalizing, you can test your chatbot to ensure it responds correctly to user inputs. This is crucial for a smooth user experience. If everything looks good, you can publish your chatbot and start using it for your business.
Finally, make sure to take advantage of the upcoming Black Friday deal on Pabi Plus. This limited-time offer will provide significant savings, allowing you to access all tools offered by Pabi.
In conclusion, integrating Now with Paby using Make allows you to create an efficient WhatsApp chatbot. By following the specific steps outlined, you can enhance user interaction and streamline your business processes.
