1. Setting Up Pabbly Connect for AI Agent
To create an automated AI agent for WhatsApp, the first step is to access Pabbly Connect. This platform enables seamless integration between various applications needed for building your AI agent.
Begin by logging into your Pabbly Connect account. Once logged in, navigate to the AI Assistant feature within Pabbly Chatbot. This feature allows you to create AI agents easily without any programming knowledge.
2. Creating Your AI Assistant in Pabbly Chatbot
To create a new AI assistant, click on the ‘Add AI Assistant’ button. You will be prompted to give your assistant a name, such as “AI Agent”. After naming your assistant, click the button to add it.
  • Select the instruction type as ‘AI Agent’.
  • Customize the instructions if desired.
  • Set the temperature for response creativity, typically around 0.5.
After setting these parameters, choose OpenAI as your AI provider and select the appropriate version, such as GPT 5.2. This setup defines how your AI agent will interact with users on WhatsApp.
3. Setting Up the OpenAI API Key
The next step involves generating an API key from OpenAI. This is crucial as it allows Pabbly Connect to communicate with OpenAI. Navigate to the API keys section on OpenAI’s website and create a new secret key.
  • Name your API key if desired.
  • Select the project and set permissions.
  • Click the ‘Create Secret Key’ button.
Once generated, copy the API key and paste it into the designated field in Pabbly Connect. This action establishes a connection between your AI assistant and OpenAI, enabling it to respond to user queries.
4. Uploading the Knowledge Base for Your AI Agent
Now, it’s time to upload the knowledge base that your AI agent will use to provide accurate responses. This knowledge base is essential for ensuring that your AI assistant gives relevant information to users.
Prepare a document in either .txt or .pdf format containing all necessary information about your business. You can use Google Docs or any text application to create this document. Once ready, upload it to Pabbly Connect by clicking on the option to add a new file.
  • Ensure the file size is under 90 MB.
  • If using PDF, limit images to 10 pages.
After uploading, select the file and click the insert button. This knowledge base will serve as the core information source for your AI agent, allowing it to answer questions accurately.
5. Finalizing and Activating Your AI Agent
To finalize your AI agent, you need to customize its appearance and activate it. In the assistant interface, you can adjust various fields such as title, subtitle, and initial message. You can also enable the option to display a message indicating it is powered by Pabbly Connect.
Once you have made all desired changes, activate your AI agent by toggling the switch and clicking the save button. This action makes your AI agent live and ready to interact with users on WhatsApp.
Additionally, configure the settings to allow your AI assistant to respond to chats. Make sure to save the automated response rules, ensuring your AI agent can assist your contacts effectively.
In this tutorial, you learned how to create an automated AI agent for WhatsApp using Pabbly Connect. By following these steps, you can efficiently automate customer interactions and enhance your business operations.
