To start automating your Slack messages, you first need to access Pabbly Connect. Open a new tab in your browser and navigate to pabbli.com/connect. This platform allows you to connect multiple applications seamlessly.
Once on the landing page, you can sign up for a free trial of Pabbly Connect. With this trial, you can send up to 100 messages for free, making it an excellent way to explore the features before committing to a subscription.
After signing up, you will be directed to the workflow builder of Pabbly Connect. This is where you will set up your automation process. Click on the ‘Add Trigger’ button to begin.
- Select ‘Scheduled by Pabbly’ as your trigger application.
- Set the event to ‘Scheduled Workflow’.
- Choose the time for your workflow, such as 9:00 AM.
Once you’ve set these parameters, click on the ‘Save’ button. Your workflow is now scheduled to run every day at 9:00 AM using Pabbly Connect.
3. Integrating OpenAI with Pabbly Connect
The next step is to generate a motivational message using OpenAI. Click on ‘Add New Action Step’ and search for OpenAI. Select it and choose the event as ‘ChatGPT’.
To connect OpenAI, you’ll need your API key. Open your OpenAI API key page, create a new secret key, and copy it. Paste this key into Pabbly Connect when prompted.
- Select the model you want to use, such as GPT-5.2.
- Enter your prompt for the motivational message.
- Click ‘Save and Send Test Request’ to generate the message.
After executing these steps, you will receive a motivational message from OpenAI, which will be sent to your Slack channel through Pabbly Connect.
4. Sending the Generated Message to Slack
Now that you have your motivational message, it’s time to send it to Slack. Click on ‘Add New Action Step’ and search for Slack. Select it and choose ‘Send Channel Message’ as the event.
If you’ve already connected Slack to Pabbly Connect, select the existing connection. If not, create a new connection and log into your Slack account. Make sure to allow the necessary permissions.
- Choose the workspace where your channel is located.
- Select the channel (e.g., Sales Team) where the message will be sent.
- Map the message from the previous step into the message field.
After completing these steps, click ‘Save and Send Test Request’. You should see a confirmation that your message was successfully sent to Slack, demonstrating how Pabbly Connect automates this process.
5. Conclusion
By following these steps, you can effectively automate daily motivational messages to your Slack team using Pabbly Connect and OpenAI. This integration enhances communication without requiring any coding skills. Experience the convenience of automation with Pabbly Connect today!
