To begin integrating WhatsApp with Pabbly Connect, first, visit the Pabbly Connect website. This platform serves as the central hub for automating your WhatsApp responses for educational queries.
Once on the website, create an account or log in. After signing in, navigate to the dashboard where you can set up your WhatsApp integration. This is crucial as it lays the groundwork for automating responses to inquiries you receive.
2. Connecting WhatsApp to Pabbly Connect
Connecting WhatsApp to Pabbly Connect is essential for automating your messaging. Start by going to the “Add WhatsApp Number” section in your dashboard. Here, you will link your WhatsApp account directly.
  • Click on “Add WhatsApp Number”.
  • Follow the prompts to connect your WhatsApp account.
  • Ensure that your WhatsApp is verified for seamless integration.
Once your WhatsApp is connected, you can start configuring automated responses. This step is crucial for ensuring your educational business can handle inquiries efficiently.
3. Creating an AI Assistant for Course Inquiries
With your WhatsApp connected, the next step is to create an AI assistant using Pabbly Connect. This assistant will respond to course inquiries automatically. Navigate to the “AI Assistant” section and click on “Add Assistant”.
Provide a name for your assistant, such as “Education AI”. You can also select the type of assistant, like a customer support agent or an AI agent. This customization allows you to tailor responses based on the type of inquiries you receive.
  • Choose the assistant type based on your needs.
  • Set the temperature for response creativity (0.5 is recommended).
  • Connect to an AI platform like OpenAI for generating responses.
This setup is vital for ensuring that your AI assistant can provide accurate and relevant answers to student inquiries.
4. Configuring the Knowledge Source for Responses
The next step in the process involves configuring a knowledge source for your AI assistant within Pabbly Connect. This knowledge base will be used by your assistant to provide answers to incoming queries.
You need to upload a text file or PDF containing all relevant information about your courses. This file should include details like course names, pricing, and FAQs. The assistant will refer to this file when responding to inquiries.
  • Create a detailed knowledge source file with course information.
  • Upload the file in the designated section of Pabbly Connect.
  • Ensure the file size is less than 90 MB for successful uploads.
By configuring this knowledge source, your AI assistant can efficiently answer student queries based on the information you provide.
5. Automating Responses for Course Inquiries
Finally, to automate responses, return to the settings in Pabbly Connect. Here, you can enable the AI auto-reply feature. This feature will allow your assistant to respond automatically to inquiries received on WhatsApp.
Select your assistant and enable the auto-reply feature. This ensures that whenever a student sends a message, the AI assistant will automatically reply based on the configured settings.
  • Enable the AI auto-reply feature in settings.
  • Assign the assistant to respond to specific contacts or all contacts.
  • Save your settings to finalize the automation.
This automation makes it easy to handle multiple inquiries without manual effort, enhancing your educational business’s efficiency.
By integrating WhatsApp with Pabbly Connect, you can automate responses for educational queries efficiently. This setup not only saves time but also improves customer satisfaction by providing instant answers to inquiries.
