1. Accessing Pabbly Connect for Your AI Assistant
To start integrating your AI assistant, you need to access Pabbly Connect. Simply enter the URL pabbly.com/chatflow in your browser. This will take you to the Pabbly Chat Flow homepage.
Here, you will see options for signing in or signing up. If you are a new user, click on the sign-up button to create a free account. This allows you to explore Pabbly Chat Flow with 100 free credits every month, giving you the opportunity to test and create your automation.
2. Creating Your AI Assistant with Pabbly Connect
Once you are logged into Pabbly Connect, navigate to the AI assistant creation page. Select the instruction type as “AI Agent.” This will allow you to create an AI assistant that responds to customer queries.
- Choose the temperature setting for the AI’s responses. A lower value means more focused answers.
- Select the AI model from OpenAI that you want to use.
- Enter your OpenAI API key to enable the AI Assistant.
After configuring these settings, your AI assistant is ready to be customized further. This process illustrates how Pabbly Connect facilitates the creation of a functional AI assistant.
3. Setting Up the Knowledge Base for Your AI Assistant
To enhance your AI assistant’s capabilities, you need to set up a knowledge base. This is where your assistant will fetch information to respond to customer queries. In Pabbly Connect, you can upload your knowledge base in .txt or .pdf format.
Follow these steps to upload your knowledge base:
- Click on the “Add New File” button in your media library.
- Select your travel agency knowledge base file and click “Insert.”
Your knowledge base will now be linked to your AI assistant, allowing it to respond accurately to customer inquiries. This shows how Pabbly Connect streamlines the integration process, making it user-friendly and efficient.
4. Customizing Your AI Assistant’s Appearance
After setting up the knowledge base, it’s time to customize your AI assistant’s appearance. In Pabbly Connect, you can modify various visual elements. Start by providing a header display name and subheading, which will be shown in the preview of your assistant.
- Choose a theme and assistant shape that fits your brand.
- Upload profile pictures for the header and assistant.
Once you are satisfied with the customization, save your settings. This step emphasizes how Pabbly Connect allows for personalized branding in your automated communications.
5. Enabling Your AI Assistant for Customer Queries
To enable your AI assistant to respond to customer queries 24/7, navigate to the inbox settings in Pabbly Connect. Here, you can enable AI auto replies for all contacts or specific contact lists.
Follow these steps to enable the AI assistant:
- Scroll down to the “Enable AI Auto Replies” option and toggle it on.
- Select the contacts you want to enable the AI assistant for.
Once enabled, your AI assistant will automatically respond to incoming messages, showcasing the efficiency of Pabbly Connect in automating customer service tasks.
In this tutorial, we explored how to integrate your AI assistant using Pabbly Connect. From accessing the platform to enabling the assistant for customer queries, each step was designed to streamline your business communication. Start using Pabbly Connect today to enhance your customer service automation!
