To get started with automating your social media posts, you first need to access Pabbly Connect. Open a new tab and type “pab.com connect” in your browser. Once you hit enter, you will be directed to the Pabbly Connect landing page.
If you are a new user, click on the “Sign Up for Free” button to create an account. Existing users should click on “Sign In”. Pabbly Connect offers a free plan that allows you to create 100 automation tasks each month, making it an excellent choice for small businesses and individuals.
After signing in, you will be directed to the Pabbly Connect dashboard. Click on the “Create Workflow” button to start building your automation. You can either create a workflow from scratch or use the Pabbly workflow builder for ease of use. Here, you will input your prompt detailing what you want the workflow to accomplish.
  • Choose a name for your workflow.
  • Define the trigger app, which will be Pabbly or Pab.
  • Set the action apps, including GPT, Facebook, and Instagram.
Once you have defined your workflow, click “Save” to proceed. The workflow will then be ready for you to configure the specific actions.
3. Configuring the Schedule for Posts
In this step, you will set up a schedule to automate your social media posts. Use the “Schedule” app within Pabbly Connect to determine how often your posts will go live. You can set it to run daily, weekly, or at specific intervals.
  • Select the frequency of posting (daily, weekly, etc.).
  • Specify the time you want the posts to be published.
After setting your preferences, save the schedule. This will ensure that your posts are generated and published automatically at the specified times.
4. Generating Content Using GPT
Next, you will integrate GPT with Pabbly Connect to generate engaging captions and images for your posts. Start by connecting to the OpenAI service through Pabbly Connect. You will need to input your API key, which you can generate from your OpenAI account.
  • Select the GPT model you want to use (e.g., GPT-3.5).
  • Input your prompt for generating captions.
  • Save and send the test request to generate content.
Once the content is generated, you can use it in your social media posts. This step is crucial for ensuring that your posts are engaging and relevant to your audience.
5. Posting to Facebook and Instagram
Finally, you will use Pabbly Connect to post the generated content to your social media accounts. Start by connecting your Instagram account to Pabbly Connect. Select the “Connect with Instagram for Business” option and authenticate your account.
After connecting, map the generated caption and image URL to the respective fields in Pabbly Connect. Then, do the same for Facebook by connecting your Facebook page. This ensures that the same content is posted to both platforms simultaneously.
  • Select the Facebook page where you want to post.
  • Map the image and caption fields from the previous steps.
Once everything is set, click “Save and send test request” to publish your posts. You can check your social media accounts to see the newly created posts, confirming that the automation has worked successfully.
In this tutorial, we explored how to automate social media posts using Pabbly Connect. By integrating Pabbly, Pab, GPT, Facebook, and Instagram, you can streamline your posting process and save time. This automation allows for consistent engagement with your audience without manual effort.
