To start integrating Google AI with Pabbly Connect, first access the Pabbly Connect platform. Open a new tab and type ‘pabbly.com/connect’ in the address bar. Hit enter, and you will be directed to the Pabbly Connect landing page.
If you are a new user, click on the ‘Sign Up for Free’ button to create an account. Existing users can click on ‘Sign In’ to log in. Pabbly Connect offers 100 free tasks monthly, allowing you to automate various processes seamlessly.
Once logged into Pabbly Connect, you can create a new workflow to integrate Google Sheets with Google AI. Click on the ‘Create New Workflow’ button, and you will be prompted to name your workflow.
  • Select ‘Google Sheets’ as your trigger application.
  • Choose the trigger event as ‘New Spreadsheet Row’.
  • Set the action application to ‘Google AI’.
After naming your workflow, click on ‘Create’ to proceed. This will set up the initial connection between Google Sheets and Pabbly Connect, allowing you to automate the image generation process.
3. Configuring Google Sheets with Pabbly Connect
Next, configure your Google Sheets to work with Pabbly Connect. In your Google Sheet, set up columns for your blog title and image prompt. This data will trigger the automation.
  • Column A: Blog Title
  • Column B: Image Prompt
After setting up your columns, return to Pabbly Connect and link your Google Sheets by following the prompts. This connection allows Pabbly Connect to capture new entries automatically, facilitating seamless integration with Google AI.
4. Integrating Google AI with Pabbly Connect
After configuring Google Sheets, the next step is to integrate Google AI. In your Pabbly Connect workflow, add a new action step and select Google AI as the application. You will need to provide your API key to establish the connection.
Once connected, specify the model you want to use for image generation. For this tutorial, select the ‘Gemini’ model. Next, map the fields from your Google Sheets to the Google AI input fields to ensure the correct data is sent for image generation.
5. Finalizing the Workflow in Pabbly Connect
Once the mapping is complete, save your workflow and run a test. Add a new row in your Google Sheets with a blog title and prompt. Pabbly Connect will trigger the workflow, sending the data to Google AI for image generation.
After a few moments, check your Google Sheets to see if the generated image URL appears in the designated column. This confirms that the integration is successful, and you can now automate the process of generating blog images based on your prompts.
This tutorial demonstrated how to integrate Google AI with Pabbly Connect to automate blog image generation using Google Sheets. By following these steps, you can streamline your content creation process and enhance your blogging efficiency.
