1. Accessing Pabbly Connect to Start Integration
To begin integrating Pabbly, Pabbly Chatbot, API, and OpenAI, first access Pabbly Connect. Open your browser and navigate to pabbly.com/chatflow. Here, you will find options to either log in or sign up for a free trial.
If you are a new user, click on “Sign Up Free” to create an account. Existing users can simply log in to their dashboard. Once logged in, navigate to the Pabbly Chatbot section to start setting up your chatbot.
2. Setting Up Pabbly Chatbot for Customer Queries
In this section, you will set up the Pabbly Chatbot to handle customer queries effectively. After logging into Pabbly Connect, click on “Access Now” under the Pabbly Chatbot option.
Once in the Pabbly Chatbot dashboard, you can connect your WhatsApp number. For those unfamiliar with the process, detailed tutorials are available on the Pabbly YouTube channel. After connecting your WhatsApp, you can begin creating your AI assistant.
- Click on “Add Assistant” to create a new AI assistant.
- Name your assistant and proceed to the flow setup.
- Select the instruction type from the dropdown menu.
Now you can customize the assistant according to your business needs. Save your settings to ensure your chatbot is ready to answer customer inquiries.
3. Configuring Your AI Assistant with OpenAI
Next, configure your AI assistant to utilize OpenAI for generating responses. In the settings of your assistant, you will find options for adjusting the temperature and selecting the AI provider. Here, you will choose OpenAI and set the model to GPT-5.4.
To connect OpenAI, you will need your API key. Click on the provided link to access your OpenAI account and generate a new API key. Copy this key and paste it into the designated field in Pabbly Connect.
- Adjust the temperature setting to control the creativity of responses.
- Add a header and footer message if desired.
- Set keywords for stopping responses when certain words are mentioned.
These configurations ensure that your AI assistant can effectively engage with customers while providing accurate information.
4. Finalizing Your Chatbot Settings in Pabbly Connect
After configuring your AI assistant, it’s time to finalize the settings. In this step, you will set up the knowledge source for your assistant. Upload the necessary documents in PDF or plain text format, as these are the only supported formats in Pabbly Connect.
Once the documents are uploaded, customize the interface of your chatbot. You can change the branding elements like the window title, subtitle, and initial messages that customers will see upon starting a chat.
- Choose color themes for the chatbot interface.
- Upload profile images for branding.
- Enable or disable the “Powered by Pabbly” label.
Make sure to save all changes and activate your chatbot so it can start responding to customer inquiries.
5. Assigning the Chatbot to Your WhatsApp
Finally, you will assign the configured chatbot to your WhatsApp account. Navigate to the settings section and locate the “AI Reply Settings” option. Here, enable the feature that allows the assistant to respond to chats.
Select the contact list from the dropdown menu and assign the specific assistant you created. Click on the save button to finalize the assignment. This ensures that your AI assistant is now ready to handle customer queries on WhatsApp through Pabbly Connect.
To assign the assistant to individual chats, simply access the WhatsApp chat, toggle the assistant feature, and select the assistant for that specific conversation. This flexibility allows you to manage multiple customer interactions seamlessly.
In this tutorial, we explored how to use Pabbly Connect to integrate Pabbly, Pabbly Chatbot, API, and OpenAI effectively. By following the steps outlined, you can create a fully functional chatbot that enhances customer interaction through WhatsApp.
