To create a WhatsApp chatbot, start by accessing Pabbly Chatflow. Open your browser and navigate to www.pabbly.com/chatflow. Here, you can sign in or sign up for a free account.
If you are a new user, click on “Sign up for free” to create your account. Existing users can simply click “Sign in”. Once logged in, you will see the Pabbly Chatflow dashboard, where you can manage your WhatsApp chatbot settings.
2. Adding Your WhatsApp Number to Pabbly Chatflow
Next, you need to add your WhatsApp number to Pabbly Chatflow. Click on the “Add WhatsApp Number” option. You can connect your WhatsApp using the preferred method or a manual token, depending on your preference.
- Click on “WhatsApp Connect” to start the connection process.
- Follow the prompts to authenticate your WhatsApp account.
- Ensure your number is verified to enable chatbot functionalities.
After successfully adding your WhatsApp number, you can proceed to create your AI assistant within Pabbly Chatflow.
3. Creating Your AI Assistant in Pabbly Chatflow
To automate responses, you need to create an AI assistant in Pabbly Chatflow. Navigate to the AI Assistant section and click on “Create New Assistant”. Name your assistant appropriately, such as “WhatsApp Chatbot”.
Choose the instruction type as “AI Agent”. You can adjust the temperature setting to define how creative or focused the AI responses should be. A setting of 0.7 is recommended for balanced responses.
- Select the AI model to use, such as OpenAI’s GPT-3.
- Input your API key to connect the AI model to your assistant.
- Configure any additional settings like fallback messages and stop keywords.
Once all settings are configured, save your AI assistant to enable automated interactions.
4. Uploading Knowledge Base for Your Chatbot
To provide your AI assistant with the necessary information, upload a knowledge base file in Pabbly Chatflow. This file should contain FAQs, services, and other relevant data.
Click on the upload option, select your file, and ensure it is in a compatible format (PDF or DOCX). This knowledge base will allow the AI to respond accurately to user queries.
- Ensure the file includes all necessary details about your services.
- Limit the file to a maximum of 10 pages to ensure smooth processing.
- Test the responses of your assistant after uploading the file.
With a well-prepared knowledge base, your chatbot will be able to provide detailed and accurate responses to users.
5. Assigning Your AI Assistant to Contacts
After creating your AI assistant, it’s time to assign it to your contacts in Pabbly Chatflow. Navigate to the inbox settings and select the AI auto-reply settings.
You can assign the assistant to specific lists or all contacts. This feature allows you to manage responses efficiently and ensure all queries are handled promptly.
- Select the assistant you created from the dropdown menu.
- Save your settings to activate the assistant for the selected contacts.
- Test the setup by sending a message to your WhatsApp number.
By following these steps, your AI assistant will now handle incoming messages, providing users with instant replies based on the configured knowledge base.
Creating a WhatsApp chatbot using Pabbly Chatflow allows you to automate repetitive queries effortlessly. By following the steps outlined, you can enhance customer interaction and streamline your business communications.
