1. Creating a WhatsApp Assistant with Pabbly Connect
To create a WhatsApp assistant that efficiently handles gym inquiries, start by accessing Pabbly Connect. This platform allows you to automate responses to common questions about membership pricing, gym timings, and trial sessions.
Begin by logging into your Pabbly Connect account. If you don’t have an account, sign up for free to access the features. Once logged in, navigate to the dashboard and look for the WhatsApp integration options. This will be essential for setting up your assistant.
2. Setting Up Your Assistant in Pabbly Connect
Next, set up your assistant in Pabbly Connect. Click on the “Add Assistant” button to initiate the process. You will be prompted to name your assistant, which could be something like “Flexa, the Fitness Assistant”.
- Select the AI agent type from the dropdown menu.
- Enter the AI instructions that define how your assistant responds.
- Set the temperature level, which adjusts the creativity of responses.
After defining these settings, proceed to save your assistant. This step is crucial as it sets the foundation for how your assistant will interact with users on WhatsApp.
3. Uploading Knowledge Source in Pabbly Connect
In this section, you will upload a knowledge base to your assistant using Pabbly Connect. This knowledge base should contain FAQs and other relevant information about your gym that the assistant can use to answer inquiries.
To upload your knowledge source, click on the “Upload File” button. Ensure your file is in PDF or TXT format. Once uploaded, the assistant will be able to reference this information when responding to user queries.
- Provide detailed information about membership plans and pricing.
- Include workout plans and trial session details.
- Ensure the file is comprehensive for accurate responses.
Once your knowledge base is uploaded, your assistant will be equipped to provide accurate information to users interacting through WhatsApp.
4. Styling Your Assistant in Pabbly Connect
After setting up the knowledge source, you can style your assistant using Pabbly Connect. This includes changing the appearance and initial messages that users will see when they interact with your assistant.
In the styling section, you can modify the assistant’s header, subheader, and even the footer message. Make sure to personalize these elements to reflect your gym’s branding and tone.
- Change the theme and shape of your assistant.
- Add a privacy policy link for user transparency.
- Customize the first message users will see when they initiate a chat.
Once you are satisfied with the styling, save your changes to finalize the appearance of your assistant.
5. Testing Your Assistant with Pabbly Connect
Finally, it’s time to test your assistant using Pabbly Connect. This involves creating a trigger in WhatsApp that activates your assistant when users send a specific keyword, such as “gym”.
To set this up, navigate to the flows section in Pabbly Connect and create a new flow. Here, you will define the trigger event based on the keyword sent by users. Drag and drop the action node to assign your assistant to respond to the keyword.
- Set the trigger keyword to activate the assistant.
- Ensure the assistant is set to respond using client messages.
- Save the flow to enable it for testing.
After saving, test the assistant by sending the keyword “gym” in your WhatsApp chat. If configured correctly, your assistant will respond with a welcome message, confirming that everything is functioning as intended.
In this tutorial, we explored how to create an AI assistant using Pabbly Connect to automate gym inquiries via WhatsApp. By following these steps, you can enhance customer interactions and streamline your gym’s communication process.
