To begin the integration process, access Pabbly Connect by visiting the official website. Once there, you can either log in or sign up for a new account. This platform is crucial for connecting Are, Pabi, and Pabbly Chat efficiently.
After logging in, you will be directed to the dashboard. Here, you can start creating workflows that will automate interactions between the applications. Follow these steps to get started:
  • Log in to your Pabbly Connect account.
  • Navigate to the workflows section.
  • Click on ‘Create New Workflow’ to initiate the integration process.
With these steps, you are now ready to set up the automation between Are, Pabi, and Pabbly Chat using Pabbly Connect.
2. Creating a WhatsApp Chatbot with Pabbly Chat
To create a WhatsApp chatbot, you will utilize Pabbly Chat. This tool allows you to automate conversations seamlessly. First, access the Pabbly Chat flow page by entering the URL provided. Here, you can either sign in or sign up for free.
Once you are on the flow page, make sure to add your WhatsApp number to your Pabbly Chat account. After that, you can set up a trigger, which is essential for initiating the chatbot. Follow these steps:
  • Select ‘Create New Flow’.
  • Choose a trigger event, such as a keyword match.
  • Enter the keyword that will initiate the chatbot, for example, ‘hello’.
This setup is crucial as it allows users to interact with the chatbot effectively, making the integration with Pabbly Connect even more powerful.
3. Designing Your Chatbot Flow in Pabbly Chat
After setting up the trigger, you can start designing the flow of your chatbot. This is where Pabbly Connect shines in facilitating interactions. You will create message blocks that represent the responses from the chatbot.
Begin by dragging and dropping a text button node to create a welcome message. You can personalize the message by including options for users to explore courses. Follow these steps to design your flow:
  • Add a text button node for the welcome message.
  • Create a button titled ‘Explore Courses’.
  • Drag in a list node to provide course options.
By following these steps, you ensure that users can easily navigate through the chatbot, enhancing their experience while interacting with your educational institute through Pabbly Connect.
4. Collecting User Information through the Chatbot
Once users select a course, you can collect their information, such as their full name and email. This is a vital part of the integration process using Pabbly Connect. You can set up input fields for users to fill in their details.
Utilize the ask question node to prompt users for their full name and email address. Here’s how to do it effectively:
  • Add an ask question node for the full name.
  • Create another ask question node for the email address.
  • Set custom fields to store the responses.
By collecting this information, Pabbly Connect enables you to automate follow-up messages and confirmations, enhancing the user experience significantly.
5. Finalizing Your Chatbot Setup
After collecting user information, it’s time to finalize your chatbot setup. This includes sending a thank you message and saving the flow. Using Pabbly Connect ensures that all interactions are automated and efficient.
Once you have configured all message blocks and questions, click the save button to store your flow. This final step is crucial for ensuring that your chatbot is ready to interact with users. Follow these steps:
  • Review all message blocks and ensure they are correctly set up.
  • Click the save button to finalize the setup.
  • Test the chatbot to ensure it functions as intended.
By completing these steps, you will have a fully functional WhatsApp chatbot that automates student interactions, all facilitated through Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to integrate Are, Pabi, and Pabbly Chat effectively. By following these steps, you can automate student interactions and streamline communication within your educational institute.
