To create an AI sales representative for WhatsApp, the first step is accessing Pabbly Connect. Visit pabbly.com/chatbot to reach the Pabbly Chatbot homepage. Here, you can either log in or sign up for a free trial if you’re a new user.
After logging in, you will be directed to the Pabbly Chatbot dashboard. Make sure to connect your WhatsApp number within your Chatbot account. This connection is crucial for the AI representative to function properly. You can find detailed instructions on connecting your WhatsApp number on the Pabbly website.
2. Creating Your AI Sales Representative Using Pabbly Chatbot
Once you are in the Pabbly Chatbot dashboard, the next step is to create your AI sales representative. Click on the “Add” button to create a new assistant. You will need to name your assistant and then proceed to the next setup screen.
- Name your AI assistant.
- Choose the type of instructions from the dropdown.
- Select or add your custom prompts.
After naming your assistant, you will be directed to a flow setup window. Here, you can specify the type of instructions and set up the AI’s responses. Ensure to configure the AI settings, such as the temperature, which controls the creativity of responses.
In this section, you will configure the AI settings for your assistant using Pabbly Connect. Set the temperature to control response creativity. A lower temperature (e.g., 0.4) yields more focused responses, while a higher temperature provides creative variations.
Next, select OpenAI as your AI provider and choose the appropriate model from the dropdown menu. You will also need to enter your OpenAI API key to connect the AI capabilities with your assistant. This is crucial for enabling your assistant to generate responses based on user queries.
- Set the temperature to 0.4 for focused responses.
- Choose OpenAI as your AI provider.
- Enter your OpenAI API key for integration.
After configuring these settings, save your changes to ensure that your AI representative is properly set up to respond to customer inquiries.
4. Setting Up the Knowledge Source for Your AI Sales Representative
To equip your AI representative with the necessary information, you need to set up a knowledge source. This is done by uploading a document containing all relevant details in PDF or plain text format through Pabbly Connect.
Once you upload the knowledge source, your AI assistant will be able to access this information to provide accurate responses to customer inquiries. This step is essential for ensuring that your assistant can handle various customer questions effectively.
- Upload a PDF or plain text document as the knowledge source.
- Ensure the document contains all relevant information.
- Confirm the upload to finalize the setup.
With the knowledge source in place, your AI representative is now ready to assist customers effectively through WhatsApp.
5. Finalizing and Activating Your AI Sales Representative
After setting up your AI sales representative, the final step is to activate it within Pabbly Connect. You will need to enable the assistant and save your configurations to make it operational.
Additionally, you can assign the assistant to specific WhatsApp conversations or set it to respond to all inquiries. This flexibility allows you to tailor the assistant’s functionality based on your business needs.
- Activate your AI assistant by enabling it in the settings.
- Assign the assistant to specific conversations if needed.
- Save all settings to finalize the setup.
Once activated, your AI sales representative is ready to handle customer inquiries on WhatsApp, providing instant responses and enhancing customer interaction.
In this tutorial, you learned how to create an AI sales representative for WhatsApp using Pabbly Connect. By following the detailed steps, you can integrate Pabbly Chatbot and OpenAI to enhance your customer service experience effectively.
