1. Introduction to Pabbly Connect for WhatsApp Integration
In this tutorial, we will explore how to use Pabbly Connect to integrate a WhatsApp AI assistant that can handle customer inquiries efficiently. This integration allows businesses to automate responses, making it easier to manage customer interactions.
As customer expectations rise, having an AI assistant powered by Pabbly Connect can significantly enhance your service. This tutorial will guide you through the steps to create an AI assistant that can answer questions about furniture and more.
2. Setting Up Pabbly Connect for Your WhatsApp Assistant
To begin, you need to access Pabbly Connect and create your account. Once logged in, navigate to the Pabbly Chartflow dashboard where you can start building your WhatsApp AI assistant. This platform provides a user-friendly interface to streamline the entire process.
Follow these steps to set up your assistant:
  • Log in to your Pabbly Connect account.
  • Access the Pabbly Chartflow by clicking on the ‘Access Now’ button.
  • Add your WhatsApp number in the settings.
After completing these steps, you will have your WhatsApp number integrated into Pabbly Connect, ready for further customization.
