To create an automated WhatsApp chatbot, start by accessing Pabbly Chatflow. Visit www.pabbly.com/chatflow in your browser. This will direct you to the Pabbly Chatflow dashboard, where you can manage your chatbots easily.
Once on the homepage, you can either sign in or sign up for free. If you are a new user, signing up will provide you with 100 free credits each month. Existing users can click on the sign-in button at the top right corner to access their account.
2. Adding Your WhatsApp Number to Pabbly Chatflow
After logging into Pabbly Chatflow, the next step is to add your WhatsApp number. This integration is crucial for enabling your chatbot to communicate through WhatsApp. Click on the ‘Add WhatsApp Number’ option.
  • Select the preferred method to connect your WhatsApp, either via WhatsApp Connect or using a manual token.
  • Follow the prompts to complete the connection process.
After successfully adding your WhatsApp number, you can proceed to create your AI assistant. This assistant will handle customer queries automatically, enhancing your business efficiency.
3. Creating Your AI Assistant with Pabbly Chatflow
To create your AI assistant, navigate to the AI Assistant option on the left sidebar in Pabbly Chatflow. Click on it, and then select ‘Create New Assistant’. You will need to name your assistant, for example, “AI Agent for Your Business”.
Next, select the instruction type as “AI Agent”. This setting allows you to customize how your AI responds to user queries. You can set various parameters such as temperature for creative responses, which ranges from 0 to 1. A setting of 0.7 is recommended for balanced responses.
  • Enter your OpenAI API key to connect the AI model.
  • Configure the header and footer messages for your chatbot.
Once the basic settings are configured, you can add fallback messages and knowledge sources to ensure your AI assistant provides detailed responses to customer queries.
4. Uploading Knowledge Base for Your AI Assistant
In this step, you will upload a knowledge base to enhance your AI assistant’s responses in Pabbly Chatflow. This knowledge base should contain all relevant company information and FAQs that your customers might ask.
To upload your file, click on the ‘Knowledge Source’ section, then select ‘Upload File’. Choose the file from your computer that contains the necessary information. Ensure the document is well-structured to facilitate accurate responses.
  • The knowledge base should include company details like name, industry, and services offered.
  • Include common queries and their detailed answers.
After uploading the knowledge base, finalize your AI assistant settings to ensure it can effectively respond to customer queries based on the uploaded information.
5. Enabling Your AI Assistant for WhatsApp Conversations
Now that your AI assistant is created and configured in Pabbly Chatflow, you need to enable it for specific WhatsApp chats. You can do this by navigating to the Inbox settings within your account.
In the Inbox settings, toggle on the AI Auto Reply feature. Select the AI assistant you just created and save the settings. This allows the assistant to respond to customer queries automatically.
  • You can apply this assistant to specific contact lists or enable it for all contacts.
  • Ensure to save your settings to activate the assistant properly.
With these steps completed, your AI assistant is now ready to handle WhatsApp conversations, providing quick and accurate responses to customer queries.
In conclusion, using Pabbly Chatflow to create an automated WhatsApp chatbot streamlines customer interactions effectively. By following these steps, you can enhance your business communication and provide timely responses to customer inquiries.
