1. Setting Up Pabbly Connect for WhatsApp AI Assistant
To create a WhatsApp AI Assistant using Pabbly Connect, start by accessing the Pabbly website. Enter Pabbly Connect in your browser to reach the homepage.
If you’re a new user, click on “Sign Up for Free”. Existing users should click “Sign In”. Once logged in, navigate to the Pabbly Apps section and select Pabbly Connect.
2. Integrating ChatGPT with Pabbly Connect
In this section, we will integrate ChatGPT for your WhatsApp AI Assistant using Pabbly Connect. Start by selecting the “Create New Workflow” option in Pabbly Connect.
- Choose a descriptive name for your workflow.
- Select “Webhooks” as your trigger application.
Once your webhook is set, proceed by selecting ChatGPT as the action application. Choose the relevant action event to get started with your AI Assistant.
3. Configuring Your AI Assistant in Pabbly Connect
Now that ChatGPT is integrated, it’s time to configure your AI Assistant. In Pabbly Connect, navigate to the AI Assistant settings.
Here, you will set parameters such as the AI model, temperature, and API key. Ensure you enter your OpenAI API key accurately to allow communication between ChatGPT and Pabbly Connect.
- Set the temperature to control response creativity.
- Define a header message for initial interactions.
- Specify a fallback message for unrecognized queries.
These settings will ensure your AI Assistant provides accurate and relevant responses to customer inquiries via WhatsApp.
4. Testing Your WhatsApp AI Assistant
After configuring the settings, it’s crucial to test your WhatsApp AI Assistant. Use Pabbly Connect to send test messages through the integrated webhook.
Check if the responses from ChatGPT are accurate and timely. This step is essential to ensure your customers receive the best possible experience when interacting with your AI Assistant.
5. Finalizing the Setup in Pabbly Connect
Once testing is successful, finalize the setup by saving your workflow in Pabbly Connect. Activate the assistant using the toggle button in the settings.
Additionally, you can embed your AI Assistant on your website by using the provided embed code. This allows seamless interaction across platforms, enhancing customer engagement.
Creating a WhatsApp AI Assistant using Pabbly Connect is a straightforward process that enhances customer interaction. With the right configurations, your AI Assistant can provide instant support, making your business more efficient.
