1. Accessing Pabbly Connect to Set Up Your Assistant
To create a smart WhatsApp assistant, you first need to access Pabbly Connect. This platform will facilitate the integration of various applications, including OpenAI and Pabbly Chat Pro.
Start by logging into your Pabbly account and navigating to the Pabbly Connect dashboard. Here, you can initiate the process to set up your assistant effectively, ensuring that all necessary applications are linked through Pabbly Connect.
2. Creating Your AI Assistant in Pabbly Chatbot
Once you are in Pabbly Connect, the next step is to create your AI assistant using Pabbly Chatbot. Click on the option to add an AI assistant and provide a descriptive name, like “Smart Home Services Assistant”.
- Select the type of instructions for your assistant.
- Choose “AI Agent” as the instruction type.
- Set the temperature to control the creativity of AI responses.
After selecting these options, you will notice that Pabbly Connect automatically generates the necessary instructions for your assistant. This ensures that the AI will respond appropriately to customer inquiries.
3. Integrating OpenAI with Pabbly Connect
To enhance your assistant’s capabilities, you need to integrate OpenAI through Pabbly Connect. Select OpenAI as your AI model provider and choose the appropriate version, such as GPT-4o.
Next, you will be prompted to enter your OpenAI API key. To obtain this key, go to the OpenAI API keys page and create a new secret key. Make sure your OpenAI account is on a paid plan to access this feature.
- Enter the name for your API key (optional).
- Select the project and set permissions as needed.
- Copy the generated API key and paste it into Pabbly Connect.
After pasting the API key, click on the connect button, and you will receive a confirmation message indicating that the API key has been saved successfully.
4. Customizing Your Assistant with Knowledge Base
With the integration complete, it’s time to customize your assistant’s responses. This involves uploading a knowledge base file, which is crucial for providing accurate and relevant answers.
To upload your knowledge base, click on the option to add a new file and select your pre-prepared document. This knowledge base acts as the brain of your AI assistant, allowing it to deliver precise information based on your business services.
- Ensure the file size is under 90 MB.
- Use formats like PDF or text files for your knowledge base.
- Customize the content to reflect your business accurately.
By effectively utilizing Pabbly Connect to manage your knowledge base, your assistant can provide tailored responses that align with your business needs.
5. Finalizing and Activating Your Assistant
After setting up your knowledge base, you can finalize your assistant’s appearance and functionality. Modify the title and initial message to reflect your brand, such as changing it to “Fix Pro Home Services”.
Once you are satisfied with the customization, activate your assistant by toggling the activation switch and saving your settings. This simple process allows you to deploy your AI assistant effectively using Pabbly Connect.
In this tutorial, you learned how to integrate OpenAI and Pabbly Chat Pro using Pabbly Connect. By following the steps outlined, you can create a smart WhatsApp assistant tailored to your business needs.
