1. Accessing Pabbly Connect for Telegram Integration
To start using Pabbly Connect for automating your Telegram messages, first, open the Pabbly Connect dashboard. If you are a new user, visit pabbl.com/connect to sign up for a free account. This allows you to explore the platform with 100 free tasks each month.
Once you have access to Pabbly Connect, you can create your automation workflows. If you decide to purchase a subscription later, various plans are available to fit your needs, including options for sole entrepreneurs and agencies.
To create a Telegram workflow, click on the “Create Workflow” button in Pabbly Connect. Choose the option to create using AI, which simplifies the process significantly. Name your workflow, for example, “Post Daily on Telegram.” This establishes the purpose of your integration.
- Click on the “Create” button.
- Type your requirements, such as “I want to daily post a good morning message on my Telegram channel for my sales team.”
- Specify your business type and the time you wish to send the message.
Once you complete these steps, Pabbly Connect will generate the necessary automation based on your input. You can then proceed to set up your Telegram bot and channel.
3. Setting Up Your Telegram Bot with Pabbly Connect
After specifying your message requirements, you need to set up a Telegram bot. Start by opening Telegram and searching for “BotFather.” This bot will help you create a new bot for sending messages.
- Send the command “/newbot” to create a new bot.
- Follow the prompts to name your bot and choose a username ending with “_bot.”
- Copy the API token provided by BotFather.
With the bot created, add it as an administrator to your Telegram channel. Ensure that it has permission to send messages. This integration is crucial for Pabbly Connect to automate the posting process effectively.
4. Getting Your Telegram Channel ID for Pabbly Connect
To complete your setup, you need to obtain your Telegram channel ID. Forward any message from your channel to the “userinfobot” on Telegram to receive your channel ID. Make sure the ID starts with a negative sign, as this is required by Pabbly Connect.
- Open your channel and select a message to forward.
- Forward it to the “userinfobot” to retrieve the channel ID.
- Alternatively, check the URL of your channel on Telegram Web for the ID.
Once you have the channel ID, paste it into Pabbly Connect to finalize your workflow setup. This will ensure that your automated messages are sent to the correct channel.
5. Testing Your Workflow in Pabbly Connect
After setting up everything in Pabbly Connect, it’s time to test your workflow. Click on the “Test My Workflow” button to see if the automation functions as expected. You should receive a test message in your Telegram channel confirming that the setup is correct.
If the message contains unnecessary symbols, you can communicate with the AI to adjust the formatting. Simply type your request, and the AI will modify the workflow accordingly. This interaction allows for a highly customized experience.
Once you confirm that the test message is satisfactory, your automation is live and scheduled to send daily messages. With Pabbly Connect, you can efficiently automate your Telegram communications without manual effort.
In this tutorial, we explored how to use Pabbly Connect to automate sending daily messages on Telegram. By following the steps to create a workflow, set up a bot, and test the integration, you can streamline your communication effortlessly.
