1. Accessing Pabbly Connect for Your Telegram Bot
To create a Telegram bot using Pabbly Connect, start by accessing the platform. Open your browser and go to pabbl.com/connect. If you are a new user, click on the “Sign Up for Free” option in the top right corner. This allows you to explore Pabbly Connect with 100 free tasks each month.
Once you have signed up, you can start building your workflow. If you already have an account, simply log in to your Pabbly Connect dashboard. This is where you will set up your Telegram bot to send daily motivational quotes.
Now that you are in Pabbly Connect, it’s time to create a workflow. Click on the “Add Trigger” button to begin. For the trigger application, select “Schedule”. This will allow you to send messages at a specific time each day.
  • Select the event as “Schedule Workflow”.
  • Set the frequency to “Every Day”.
  • Choose the time as “10:00 AM”.
After setting up the trigger, click on “Save”. This schedules your workflow to run daily at the specified time, ready to send your motivational quotes.
3. Integrating Google Gemini with Pabbly Connect
The next step is to integrate Google Gemini to generate the motivational quotes. Click on “Add New Action Step” and search for Google Gemini. Select it and choose the event as “Generate Content”.
If this is your first time connecting Google Gemini with Pabbly Connect, click on “Add New Connection”. You will need to enter your API key from Google AI Studio. To obtain this key, navigate to the “Get API Key” section in Google AI Studio and create a new API key.
4. Setting Up Your Telegram Bot
Now that you have your content generated, it’s time to set up your Telegram bot. Click on “Add New Action Step” again and search for “Telegram Bot”. Choose the event as “Send a Text Message”.
To create a new bot, search for “BotFather” in Telegram. Start a chat and type /newbot to create your bot. Follow the prompts to name your bot and choose a username, ensuring it ends with “_bot”. After creation, copy the API token provided and paste it into Pabbly Connect.
  • Add the bot to your Telegram group.
  • Grant admin access to the bot.
  • Copy the chat ID from your group.
Paste the chat ID into Pabbly Connect to complete the setup. This allows your bot to send messages to the group.
5. Finalizing Your Automation with Pabbly Connect
With everything set up, it’s time to finalize your automation. Ensure that the text message from Google Gemini is mapped correctly in Pabbly Connect. Click on “Save and Send Test Request” to test your workflow.
If everything is configured correctly, you will receive a confirmation that the message has been sent. Now, your Telegram bot will send motivational quotes daily at 10 AM. This showcases the power of Pabbly Connect in automating tasks seamlessly.
Congratulations! You have successfully created a Telegram bot that sends daily motivational quotes using Pabbly Connect. This automation can save you time and keep your team motivated.
In this tutorial, we demonstrated how to use Pabbly Connect to create a Telegram bot that sends daily motivational quotes. By following these steps, you can automate your communication effectively.
