To start the process of integrating a WhatsApp AI assistant, you need to access Pabbly Connect. Open your browser and go to the Pabbly website. If you’re a new user, click on “Sign up for free” to create an account. Existing users can simply sign in to their accounts.
Once logged in, navigate to the Pabbly applications window. Select Pabbly Connect to access the integration dashboard. Here, you will find options to connect various applications including WhatsApp and other AI tools.
2. Setting Up Your WhatsApp AI Assistant
To create your WhatsApp AI assistant, access the Pabbly Chatflow feature. Click on the “AI Assistant” option in the left sidebar. Here, you can see the total number of active and inactive assistants.
- Click the “Add” button to create a new assistant.
- Provide a name for your assistant and click “Add”.
- You will be directed to a flow window to configure your assistant.
In this flow window, select the instruction type from the dropdown. Choose options like “AI agent” or “customer support agent”. This is how Pabbly Connect allows you to customize your assistant’s functionality.
Once you have created your assistant, it’s time to configure the AI settings. Set the temperature to determine how creative the responses should be. For focused answers, set it around 0.4.
Next, select the AI model you want to use. For instance, you can choose OpenAI and then select the model such as GPT-5.2 from the dropdown. This is crucial as it defines how your assistant will respond to queries.
- Add your OpenAI API key to connect the assistant.
- Configure the header and footer messages for a personalized touch.
- Specify stop keywords that will halt the assistant’s responses.
These configurations ensure that your assistant is tailored to meet your business needs. Using Pabbly Connect simplifies this process significantly.
4. Finalizing Your WhatsApp AI Assistant
After configuring the AI settings, you can finalize your assistant. Upload any required documents that contain knowledge sources. Make sure to use plain text or PDF formats, as these are the only supported types.
Next, set the assistant’s interface by adding your brand name and customizing the initial messages. You can also adjust the styling options to match your brand identity. This is where Pabbly Connect shines, allowing for extensive customization.
- Enable the assistant by toggling the activation button.
- Click the “Save” button to save your settings.
- Consider embedding the assistant on your website for greater accessibility.
These steps are essential for ensuring your WhatsApp AI assistant functions effectively and meets customer expectations. Pabbly Connect facilitates this entire setup, making it user-friendly.
5. Assigning Your Assistant to WhatsApp Chats
To assign your new assistant to WhatsApp chats, navigate to the inbox settings in the Pabbly Chatflow dashboard. Under “AI Auto Reply Settings”, enable the auto-reply feature.
Select the contact list that you want to assign the assistant to, and then choose the specific assistant you created. This bulk assignment process is streamlined through Pabbly Connect, ensuring efficiency.
- Click on the “Save” button to finalize the assignment.
- For single chats, select the specific chat and assign the assistant individually.
By following these steps, your WhatsApp AI assistant will be ready to respond to customer queries automatically. This integration showcases how Pabbly Connect can enhance your business communication.
In this tutorial, we explored how to integrate a WhatsApp AI assistant using Pabbly Connect. By following these detailed steps, you can streamline your business communication effectively.
