To begin, access Pabbly Connect by visiting the official website. Once there, you can sign in or create a new account. This platform is crucial for integrating various applications, including WhatsApp and Google Sheets.
After logging in, navigate to the dashboard. Here, you will find options to create a new workflow. Click on “Create Workflow” and give it a name related to your WhatsApp chatbot integration. This step is essential as it sets the foundation for your automation.
2. Configuring the WhatsApp Chatbot with Pabbly Connect
In this section, you will configure your WhatsApp chatbot using Pabbly Connect. Start by selecting WhatsApp as your trigger application. You will need to set the trigger event to “New Message” to initiate the chatbot whenever a message is received.
- Choose “New Message” as the trigger event.
- Connect your WhatsApp account by following the on-screen instructions.
- Test the connection to ensure everything is set up correctly.
After configuring the trigger, you will see a test message in your Pabbly Connect dashboard. This confirms that your WhatsApp integration is working. Proceed to set up actions that will follow this trigger.
Next, you will connect Google Sheets to your WhatsApp chatbot using Pabbly Connect. Select Google Sheets as your action application. The action event should be set to “Create Spreadsheet Row” to log the data received from WhatsApp.
In the action setup, you will need to specify the Google Sheets account you want to connect. Choose the specific spreadsheet and worksheet where the data will be stored. This setup is crucial for tracking interactions with your chatbot.
- Select the Google Sheets account and authorize access.
- Choose the spreadsheet and worksheet for data logging.
- Map the fields from WhatsApp to the corresponding columns in Google Sheets.
Once you have mapped the fields, test the action to ensure that the data is being recorded correctly in Google Sheets. This will help you verify that your integration is functioning as intended.
4. Finalizing the Chatbot Workflow in Pabbly Connect
After successfully connecting both WhatsApp and Google Sheets through Pabbly Connect, it’s time to finalize your chatbot workflow. Add any additional actions that you want the chatbot to perform, such as sending confirmation messages or handling user queries.
You can utilize the AI assistant feature in Pabbly Connect to automate responses based on user inquiries. This will enhance your chatbot’s functionality and provide a better user experience. Make sure to set up the knowledge base that the AI assistant will use for responding to queries.
To finalize, review all your settings and ensure that everything is configured correctly. Save your workflow, and you can now test your WhatsApp chatbot to see how it performs in real-time.
5. Testing and Using Your WhatsApp Chatbot
Now that your WhatsApp chatbot is set up through Pabbly Connect, it’s time to test its functionality. Start by sending a message to your WhatsApp number to see how the chatbot responds. Ensure that it captures data accurately and logs it into Google Sheets.
As you test, check for any issues or areas for improvement. Make adjustments as necessary in Pabbly Connect to optimize the chatbot’s performance. This iterative process will help you refine the user experience and ensure that all queries are handled efficiently.
Once testing is complete, you can confidently deploy your WhatsApp chatbot for your business. This automation will save you time and enhance customer interactions, allowing you to focus on other important aspects of your operations.
In this tutorial, you learned how to integrate WhatsApp with Google Sheets using Pabbly Connect. By following these steps, you can automate your real estate chatbot workflow, streamline customer interactions, and improve data management.
