1. Introduction to Pabbly Connect and WhatsApp Integration
Pabbly Connect is a powerful integration platform that allows you to automate workflows between various applications, including WhatsApp. In this tutorial, we will create an automated WhatsApp chatbot that can handle inquiries and book site visits for real estate properties.
This process eliminates the need for manual replies, allowing your business to respond instantly to customer inquiries. With Pabbly Connect, you can set up triggers and actions that will streamline your communication processes.
2. Setting Up Pabbly Connect for WhatsApp Chatbot
To get started, you need to access Pabbly Connect. Open a new tab and go to Pabbly Connect by navigating to pabblaby.com/chartflow. If you’re a new user, click on the “Sign Up Free” option to create an account and receive 100 free credits every month.
Once you log in, you will be directed to the dashboard of Pabbly Connect. Here’s how to set up your WhatsApp chatbot:
- Add your WhatsApp number in your Pabbly Connect account.
- Navigate to the “Flows” feature on the left-hand side.
- Click on the “+ Add Flow” button to create a new chatbot flow.
After completing these steps, you are ready to design your chatbot flow using the drag-and-drop builder available in Pabbly Connect.
