1. Accessing Pabbly Connect for WhatsApp Automation
To start automating your WhatsApp conversations, first, you need to access Pabbly Connect. Open your browser and navigate to the Pabbly website. If you are a new user, sign up for a free account to get started. Existing users can simply log in.
Once you’re logged in, you will see the Pabbly dashboard. From here, you can access various Pabbly applications, including Pabbly Connect. This platform will be essential for integrating WhatsApp with your AI assistant.
2. Setting Up WhatsApp Integration with Pabbly Connect
After logging into Pabbly Connect, you need to add your WhatsApp number. Click on the “Add WhatsApp Number” button and choose the preferred connection method. You can connect via WhatsApp connect or use a manual token.
- Select “WhatsApp Connect” for a seamless setup.
- Follow the prompts to authorize your WhatsApp account.
- Ensure your WhatsApp number is active to receive messages.
Once your WhatsApp number is connected, you can proceed to create your AI assistant. The integration allows for automated responses based on user queries, enhancing your business communication.
3. Creating Your AI Assistant in Pabbly Connect
To create an AI assistant, navigate to the AI assistant section in Pabbly Connect. Click on “Create New AI Assistant” and name it according to your business, such as “Real Estate Bot”. This bot will handle inquiries for your real estate business.
Next, set the AI instructions and configurations. Choose the instruction type as “AI Agent” and adjust the temperature settings to control the creativity of the responses. A setting of 0.7 is recommended for balanced replies.
- Select OpenAI as the AI model.
- Enter your API key from OpenAI to enable the assistant.
- Set up a fallback message for unresponsive queries.
After configuring your AI assistant, save the settings. This assistant will now be capable of answering user questions, making it a vital part of your WhatsApp automation.
4. Uploading the Knowledge Base for Your AI Assistant
A comprehensive knowledge base is essential for your AI assistant to provide accurate responses. In Pabbly Connect, navigate to the knowledge source section and upload a document that contains all relevant information about your business.
This document should include details like business name, services offered, pricing, and contact information. Once the document is uploaded, ensure that it’s correctly linked to your AI assistant.
- Create a structured document in Google Docs or a similar platform.
- Download the document in PDF or TXT format before uploading.
- Ensure the document is detailed to enable informative responses.
Once your knowledge base is uploaded, your AI assistant will have the necessary information to assist users effectively, answering queries about your real estate listings and services.
5. Enabling Your AI Assistant in Chats with Pabbly Connect
After setting up your AI assistant and knowledge base, it’s time to enable it in your WhatsApp chats using Pabbly Connect. Access the inbox settings and toggle on the AI assistant feature for specific chats or groups.
You can also automate the assignment of your AI assistant to all contacts or specific lists. This ensures that every user receives automated replies without manual intervention.
- Select the AI auto-reply settings in your inbox configuration.
- Choose the AI assistant you created earlier.
- Save the settings to finalize the automation.
With these steps completed, your AI assistant is now fully integrated and ready to handle inquiries on WhatsApp, providing quick and accurate responses to your customers.
In this tutorial, we explored how to automate WhatsApp conversations using Pabbly Connect. By creating an AI assistant and integrating it with your knowledge base, you can streamline customer interactions and enhance your business efficiency.
