To start integrating your WhatsApp AI chatbot, first access Pabbly Connect. If you are an existing user, simply log in to your account. New users can visit pabbl.com/chartflow to sign up for free, receiving 100 credits monthly to explore the features.
Once logged in, you will find the AI assistant feature of Pabbly Connect. Ensure that you have added your WhatsApp number to proceed. This is crucial for the chatbot to function properly. After setting up your WhatsApp number, you can begin creating your AI chatbot.
2. Creating Your WhatsApp AI Chatbot
In this section, we will create the WhatsApp AI chatbot using Pabbly Connect. Start by selecting the AI instructions. You have the option to input a custom prompt or select from pre-defined examples. Choosing an example will automatically populate the fields with relevant instructions.
  • Select a custom prompt or an example from the options provided.
  • Adjust the temperature setting to determine the creativity of responses.
  • Input the OpenAI API key as required to connect the AI model.
After setting these options, click on the connect button to save your configurations. This step is vital as it allows Pabbly Connect to utilize the AI model for your chatbot.
3. Customizing Your Chatbot Settings
Next, we will customize various settings of your WhatsApp AI chatbot through Pabbly Connect. You can set header and footer messages, specify stop keywords, and adjust fallback attempts. Each of these settings enhances user interaction.
  • Enter header and footer messages with a maximum of 60 characters.
  • Add stop keywords by typing them and pressing enter.
  • Specify the number of fallback attempts for the AI assistant.
Make sure to switch on the toggle buttons for any features you want to enable. These settings allow Pabbly Connect to manage user interactions effectively and ensure smooth communication.
4. Uploading Your Knowledge Base
Uploading a knowledge base is crucial for your WhatsApp AI chatbot’s functionality in Pabbly Connect. Start by creating a Google Doc containing all relevant business information, such as FAQs, pricing, and product details. Once completed, download this document in TXT format for best results.
  • Choose between TXT or PDF formats for your knowledge base.
  • Upload the file via the upload section in Pabbly Connect.
  • Insert the uploaded file to finalize your knowledge base.
This knowledge base will serve as the primary resource for your AI chatbot, allowing it to respond accurately to user queries based on the information you provide.
5. Testing Your WhatsApp AI Chatbot
After setting up your WhatsApp AI chatbot, it’s time to test its functionality using Pabbly Connect. Open your WhatsApp and send a message to initiate the conversation with your chatbot. Use the initial message you set earlier to start the chat.
Ask various questions from your uploaded knowledge base to see how the AI responds. For instance, you can inquire about customization options or pricing. The AI chatbot should provide accurate responses based on the information in your knowledge base, showcasing the effectiveness of Pabbly Connect in managing user interactions.
In this tutorial, we demonstrated how to create and customize a WhatsApp AI chatbot using Pabbly Connect. By following these steps, you can leverage the power of automation to enhance user experience and streamline communication in your business.
