To start automating daily motivation posts on LinkedIn, you first need to access Pabbly Connect. Visit the Pabbly website by typing pabby.com in your browser. If you are a new user, click on “Sign up for free” to create an account and get 100 free tasks monthly. Existing users should click on “Sign in” in the top right corner.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the “Create Workflow” button. Name the workflow something descriptive, like “Create a Daily LinkedIn Motivation Machine with AI,” and select an appropriate folder for organization.
2. Setting Up Google Sheets as a Trigger
In this step, we will set Google Sheets as the trigger application in Pabbly Connect. This means that whenever a new row is added or updated in Google Sheets, it will trigger the workflow. Select Google Sheets as your trigger application and choose the event “New or Updated Spreadsheet Row” from the dropdown menu.
To connect Google Sheets with Pabbly Connect, you will need to set up a webhook. Follow these steps:
  • Go to Extensions in Google Sheets.
  • Click on Add-ons and then Get Add-ons.
  • Search for Pabbly Connect Webhooks and install it.
After installation, refresh your Google Sheets document and navigate to Extensions > Pabbly Connect Webhooks > Initial Setup. Here, paste the webhook URL provided by Pabbly Connect and specify the trigger column, which will be the final data column (e.g., Column F).
3. Integrating OpenAI to Generate Content
Next, we will integrate OpenAI into our workflow using Pabbly Connect. This integration will allow us to generate motivational posts based on the data entered in Google Sheets. In the action application, select OpenAI and choose the event “Chat GPT”. Click on connect and enter your API token to establish the connection.
To obtain the API token, go to the OpenAI API keys page and create a new secret key. Enter a name for the key and click on “Create Secret Key”. Copy the generated token and paste it into Pabbly Connect. After setting up the connection, specify the AI model (e.g., GPT-4) and create a prompt for generating the LinkedIn post.
4. Posting to LinkedIn via Pabbly Connect
Now that we have generated the motivational content using OpenAI, it’s time to post it to LinkedIn. In this step, select LinkedIn as the action application within Pabbly Connect. Choose the event “Share Simple Text” and connect your LinkedIn account by entering your credentials.
Once connected, you will need to map the content generated by OpenAI to the LinkedIn post. Select the author and set the visibility to public. Finally, click on “Save and Send Test Request” to verify that the post is successfully created on your LinkedIn profile.
5. Conclusion: Automating Your LinkedIn Posts
By following the steps outlined above, you can effectively automate daily motivation posts on LinkedIn using Pabbly Connect, Google Sheets, and OpenAI. This integration allows for seamless posting without manual effort, ensuring that your LinkedIn feed remains active and engaging.
With this automation, you can focus on other important tasks while maintaining a consistent presence on LinkedIn. Start using Pabbly Connect today to streamline your social media management!
