1. Setting Up Pabbly Connect for Telegram Integration
To begin the integration process, you first need to access Pabbly Connect. This platform allows you to automate workflows between different applications seamlessly. Start by logging into your Pabbly Connect account, where you can create a new workflow for your Telegram bot.
Once logged in, you will find an option to create a new workflow. Click on it, and you will be prompted to name your workflow. This name should reflect the purpose of your integration, such as “OpenAI Telegram Bot”. After naming your workflow, you can proceed to set up the trigger event.
2. Creating Your Telegram Bot
Next, you will need to create a Telegram bot. Open your Telegram app and search for the “BotFather” to initiate the bot creation process. Start a chat with BotFather and select the option to create a new bot.
  • Click on the “New Bot” option.
  • Provide a name for your bot, such as “MyTelegramBot”.
  • Choose a unique username for your bot that ends with “bot”.
After creating the bot, BotFather will provide you with an API token. This token is crucial as it will be used in Pabbly Connect to establish a connection with your Telegram bot.
3. Connecting Pabbly Connect with Telegram
In your Pabbly Connect account, go to the workflow you created and set up the trigger. Select Telegram as the app and choose the trigger event as “New Message”. You will be prompted to enter the API token you received from BotFather.
Paste the token into the designated field in Pabbly Connect and click on the “Save” button. This action will connect your Telegram bot to Pabbly Connect, allowing it to capture messages sent to your bot.
Once the connection is established, you can test it by sending a message to your Telegram bot. If everything is set up correctly, Pabbly Connect will capture the message and display it in your workflow.
4. Integrating OpenAI with Telegram via Pabbly Connect
Now that your Telegram bot is connected, the next step is to integrate OpenAI. In your Pabbly Connect workflow, add a new action step and select OpenAI as the application. Choose the action event as “Generate Response”.
  • Enter your OpenAI API key to connect it with Pabbly Connect.
  • Set the model to use, such as GPT-4.
  • Map the user’s message from Telegram to the prompt field in OpenAI.
After configuring these settings, save the action step. This integration allows your Telegram bot to send user queries to OpenAI and receive generated responses automatically.
5. Sending Responses Back to Telegram
Finally, you need to set up the last action in your Pabbly Connect workflow to send the generated responses back to your Telegram group. Add another action step, select Telegram, and choose the action event as “Send Message”.
In the setup, you will need to provide the chat ID of your Telegram group, which you can find in the group settings. Map the response generated by OpenAI to the message field in this action. After completing the setup, click on the “Save” button to finalize the workflow.
Now, whenever someone sends a message to your Telegram bot, it will automatically generate a response using OpenAI and send it back to the group, demonstrating the power of Pabbly Connect in automating your Telegram interactions.
Integrating OpenAI with Telegram using Pabbly Connect allows you to create a powerful automated bot that responds to user queries efficiently. This tutorial has guided you through the setup process, showcasing how Pabbly Connect facilitates seamless integration.
