To start automating notifications from WordPress to Discord, you need to access Pabbly Connect. This platform allows seamless integration between various applications.
Begin by visiting the Pabbly Connect dashboard at pabbly.com/connect. Here, you can either sign up for a free account or log in if you are an existing user. New users can explore the platform with 100 free tasks per month.
Once logged into Pabbly Connect, click on the “Create Workflow” button to initiate the automation process. This will allow you to set up the integration between WordPress and Discord.
  • Select the “Quick Builder” option for easy setup.
  • Enter a prompt like “Integrate WordPress and Discord”.
  • Choose WordPress as the trigger app and select “New Post Publish”.
After setting up the trigger, choose Discord as the action app and select “Send Channel Message”. Approve the workflow to proceed.
3. Configuring WordPress for Webhooks
Next, you need to configure your WordPress account to connect with Pabbly Connect. This involves adding a webhook URL to your WordPress settings.
Install the “WP Webhooks” plugin from the WordPress plugin repository. After installation, navigate to the plugin settings and select the option to send data. Here, add the webhook URL generated by Pabbly Connect.
  • Set the webhook trigger to “Post Created”.
  • Name the webhook (e.g., “Discord Blog”).
  • Save the settings to finalize the integration.
With the webhook URL saved, your WordPress site is now configured to send notifications to Pabbly Connect.
4. Testing the Integration with a New Post
To ensure everything is set up correctly, create a new post in WordPress. This action will trigger the webhook and send data to Pabbly Connect.
After publishing the post, return to the Pabbly Connect dashboard and click on “Capture Webhook Response”. This will allow you to see if the data from your new post has been received successfully.
Once you confirm that the response includes the post title and URL, proceed to set up the Discord message. This step is crucial for notifying your community about the new blog post.
5. Sending Notifications to Discord
Now it’s time to configure the Discord channel to receive notifications from Pabbly Connect. Go to your Discord server and create a webhook for the channel where you want to send messages.
Copy the webhook URL and paste it into your Pabbly Connect workflow. Here, you can customize the message that will be sent to your Discord channel, including dynamic fields like the post title and URL using mapping.
  • Map the title and URL from the WordPress response.
  • Click “Save and Send Test Request” to send a test message.
  • Check your Discord channel for the notification.
If the message appears in Discord, your integration is successful! You can now automate notifications for every new WordPress post using Pabbly Connect.
By following this tutorial, you can easily automate notifications from WordPress to Discord using Pabbly Connect. This integration keeps your community engaged with real-time updates about your new blog posts.
