To integrate OpenAI with WhatsApp, you will first need to access Pabbly Connect. Start by visiting the official Pabbly website and navigating to the Pabbly Connect section. Once there, you can sign up for a free account if you are a new user or log in if you already have an account.
After logging in, you will be directed to the Pabbly Connect dashboard where you can create a new workflow. This is the central hub for managing your integrations. Follow these steps to get started:
- Sign up or log in to your Pabbly Connect account.
- Navigate to the dashboard and select “Create New Workflow”.
- Name your workflow for easy identification.
Now that you have set up your workflow, you are ready to proceed with the integration process.
2. Setting Up the OpenAI API in Pabbly Connect
Next, you need to configure the OpenAI API within Pabbly Connect. This step is crucial for enabling your AI assistant to interact with WhatsApp. You will need to obtain your OpenAI API key from the OpenAI website. Here’s how to do it:
To get your API key, visit the OpenAI API keys page and create a new secret key. Make sure to save this key securely. Once you have your API key, go back to Pabbly Connect and follow these steps:
- Select the OpenAI integration from the list of applications.
- Paste your API key into the designated field.
- Test the connection to ensure it’s working properly.
With your OpenAI API successfully integrated, you can now move on to configuring the WhatsApp integration through Pabbly Connect.
