To start the integration process, you need to access Pabbly Connect. Open your browser and navigate to pabby.com/connect. This platform is essential for automating the connection between your Instagram leads and WhatsApp.
If you’re a new user, click on “Sign Up for Free” to get started. Existing users can simply sign in. After signing in, you will see the Pabbly apps window. Click on “Access Now” under Pabbly Connect to reach the dashboard.
In Pabbly Connect, workflows are the backbone of your automation. To create a workflow, select the method you prefer. For this tutorial, we will use the quick filter method.
  • Select the app and app event.
  • Choose “Connect with Instagram Lead Ads” as the trigger.
  • Grant access to your Facebook account linked with Instagram.
Once connected, select your Facebook page and the specific lead form you want to capture leads from. This setup ensures that every lead generated will be processed through Pabbly Connect.
3. Generating a Test Lead
To test your setup, you need to generate a test lead. Use the lead testing tool provided by Meta. Select your Facebook page and lead form, then enter dummy details for the lead.
  • Enter a random business name.
  • Provide a dummy email and full name.
  • Include your phone number to receive WhatsApp messages.
After submitting the form, check your WhatsApp. You should receive an automated message confirming the lead capture, demonstrating how Pabbly Connect seamlessly integrates these platforms.
4. Setting Up WhatsApp Communication
Next, you will configure WhatsApp communication in Pabbly Connect. Choose Pabbly Chatflow as your messaging platform. You will need to obtain an API token from the settings section of Pabbly Chatflow.
After acquiring the token, paste it into the appropriate field in Pabbly Connect. Once connected, map the phone number of your lead to ensure that messages are sent directly to them. This mapping feature is crucial for dynamic communication.
5. Testing the Integration
Finally, it’s time to test the entire integration process. Click on “Save and Send Test Request” to initiate the WhatsApp message. Ensure that the message includes the lead’s name for personalization.
Check your WhatsApp to confirm that the message has been received successfully. This step validates that Pabbly Connect has effectively automated the communication process between Instagram leads and WhatsApp.
In this tutorial, we explored how to integrate Instagram leads into WhatsApp using Pabbly Connect. This automation enhances communication efficiency, allowing businesses to convert leads into sales seamlessly.
