To start integrating Google Ads with Go High Level, the first step is to access Pabbly Connect. Visit the Pabbly website by typing pabbly.com in your web browser. Once on the site, you can either sign in or sign up for a free account, which gives you 100 tasks monthly.
After signing in, you will see the Pabbly apps page. Click on the Pabbly Connect icon to access the dashboard, where you can create and manage your workflows. This platform is essential for connecting Google Ads with Go High Level seamlessly.
In this section, we will create a new workflow in Pabbly Connect to automate the process. Click on the “Create Workflow” button and name it “Connect Google Ads with Go High Level for Faster Follow-Ups.” Choose a folder for organization, such as “All Automations,” and click on “Create” to proceed.
- Select Google Ads as the trigger application.
- Choose “New Lead Form Entry” as the trigger event.
- Click on “Connect Now” to establish a connection.
After setting up the trigger, you will receive a webhook URL from Pabbly Connect that acts as a bridge between Google Ads and Pabbly Connect. This URL is crucial for receiving lead data from Google Ads.
3. Setting Up Google Ads to Use Webhook
Next, navigate to your Google Ads account to set up the webhook URL provided by Pabbly Connect. In the Google Ads interface, create a test lead form. Fill in the required fields like first name, last name, email, and phone number.
Once the form is ready, scroll to the lead delivery option and paste the webhook URL from Pabbly Connect. After entering the key, click on “Send Test Data” to verify the connection. If successful, you will see a confirmation in your Pabbly Connect workflow.
4. Adding Action Steps in Pabbly Connect
After confirming the webhook connection, the next step is to add action steps in Pabbly Connect. Click on “Add New Action” and search for “Lead Connector V2.” Choose “Create a Contact” as the action event and click on “Connect.”
If you have an existing connection, select it; otherwise, create a new one. Grant permission to access your Go High Level account, and select the appropriate sub-account to ensure the integration works smoothly. Mapping the fields from Google Ads to Go High Level is crucial for accurate data transfer.
- Map first name, last name, email, and phone number from Google Ads.
- Ensure fields are set to dynamic to capture new responses.
- Click “Save and Send Test Request” to finalize the setup.
Upon successful mapping, you will receive a confirmation response that indicates the lead has been created in Go High Level, completing the integration process using Pabbly Connect.
5. Conclusion
In this tutorial, we demonstrated how to integrate Google Ads with Go High Level using Pabbly Connect. This automation allows you to manage leads effortlessly without manual intervention. By following the steps outlined, you can streamline your lead management process effectively.
Using Pabbly Connect not only saves time but also ensures that your leads are captured accurately and promptly, enhancing your marketing efforts. Start automating your workflows today!
