To start using Pabbly Connect, open a new tab and search for pabbly.com/connect in your browser. This will take you to the landing page of Pabbly Connect.
In the top right corner, click on the ‘Sign Up for Free’ button to create a new account. After signing up, you can explore Pabbly Connect’s features. If you find it useful, consider purchasing a subscription plan to unlock its full potential.
Once you are logged into Pabbly Connect, you will be directed to the workflow builder. Here, you can create your automation by setting up triggers and actions. Click on the ‘Add Trigger’ button to begin.
For this integration, search for Typeform as your trigger application and select it. Choose the ‘New Entry’ event, and click on ‘Connect’. If you haven’t previously connected Typeform, select ‘Add New Connection’ and log into your Typeform account to authorize the connection.
3. Setting Up Typeform in Pabbly Connect
After connecting Typeform with Pabbly Connect, you need to select the specific form you want to use for this integration. Ensure that the response format is set to ‘Advanced’ and then click on ‘Save and Send Test Request’. This will allow Pabbly Connect to capture the response from your form.
To test this, open the Typeform link in a new tab and fill out the registration form. Once you submit the form, return to Pabbly Connect to see that the response has been captured successfully.
4. Integrating Discord with Pabbly Connect
Next, you will set up the action step to send notifications to Discord. Click on ‘Add New Action Step’ and search for Discord, then select it. Choose the ‘Send Channel Message’ event and click on ‘Connect’. Again, ensure you are logged into your Discord account before proceeding.
After connecting Discord, you will need to get the webhook URL and token from your Discord channel. Go to the channel settings, navigate to ‘Integrations’, and create a new webhook. Copy the webhook URL and paste it into Pabbly Connect. Extract the webhook ID and token from this URL as instructed.
  • Copy the webhook URL from Discord.
  • Extract the webhook token and ID from the URL.
  • Paste the token and ID into the respective fields in Pabbly Connect.
Now, compose the message text that will be sent to your Discord channel. Use the mapping feature in Pabbly Connect to dynamically insert form submission details into the message.
5. Testing the Integration
To finalize the setup, click on the ‘Save and Send Test Request’ button in Pabbly Connect. If everything is set up correctly, you will receive a confirmation that the message has been sent to your Discord channel.
This automation is now complete! Whenever someone fills out the Typeform, a notification will automatically be sent to your Discord channel without needing to manually check for entries. This seamless integration showcases the power of Pabbly Connect in automating workflows.
In this tutorial, we demonstrated how to integrate Typeform with Discord using Pabbly Connect. This automation notifies your team instantly upon new form submissions, enhancing communication and efficiency.
