To start integrating Calendly with Asana, you first need to access Pabbly Connect. This platform is essential for automating your workflows without any coding knowledge. Simply visit the Pabbly Connect website and create a free account to get started.
Once you sign up, you will receive 100 free tasks every month to explore the software. After logging in, you’ll be directed to the Pabbly Connect dashboard where you can manage your automation workflows. Click on the ‘Create Workflow’ button to initiate the integration process.
Creating a workflow in Pabbly Connect is straightforward. You can choose to create a workflow using the Quick Builder for a faster setup. In the Quick Builder, you simply enter a prompt like “connect Calendly to Asana”.
  • Select the trigger event from Calendly, such as ‘Invitee Created’.
  • Choose the action event in Asana, like ‘Create a Task’.
  • Approve the workflow creation to finalize.
This method allows you to quickly set up the workflow you need. After approval, you can see the applications connected and ready for further configuration.
3. Connecting Calendly and Asana in Pabbly Connect
To connect Calendly and Asana using Pabbly Connect, click on the Calendly application within your workflow. Select the ‘Connect’ button to establish a connection. If you already have a connection, you can choose that option instead.
After selecting to add a new connection, click on ‘Connect with Calendly’. If your Calendly account is logged in, it will connect automatically. Next, choose the organization and user that you want to link to Pabbly Connect.
  • Select the response format that suits your needs: Simple, Advanced, or Raw.
  • Save your connection settings to proceed.
This setup ensures that every time a meeting is booked in Calendly, Pabbly Connect will capture the details for further processing in Asana.
4. Testing the Integration between Calendly and Asana
After setting up the connection, it’s crucial to test the integration using Pabbly Connect. Schedule a test meeting in Calendly to see if the workflow captures the booking details correctly. For instance, fill in the meeting details and click on the ‘Schedule Event’ button.
Once the meeting is scheduled, return to Pabbly Connect and check for a new response from Calendly. If successful, you should see the meeting details populated correctly. This confirms that the trigger is working as intended.
  • Verify the meeting date and time format received from Calendly.
  • Ensure that all necessary fields are captured for the next steps.
Testing is essential to confirm that the integration is seamless and that no details are missed in the process.
5. Finalizing and Activating the Workflow in Pabbly Connect
With the integration tested and confirmed, it’s time to finalize your workflow in Pabbly Connect. Click on the Asana application within your workflow to connect it similarly to how you did with Calendly. Select the project you want to use for task creation.
Map the fields from the Calendly response to the Asana task fields. For instance, include the client’s name, meeting date, and requirements in the task notes. After mapping, click on the ‘Save and Send Request’ button to complete the task setup.
  • Ensure that you enable the toggle for the workflow to activate it.
  • Regularly check the workflow to ensure it operates smoothly.
Once activated, every meeting booked in Calendly will automatically create a task in Asana, saving valuable time and ensuring no follow-ups are missed.
In this tutorial, we explored how to integrate Calendly with Asana using Pabbly Connect. This automation streamlines your workflow, enabling automatic task creation for every meeting scheduled. By following these steps, you can enhance productivity and reduce manual tasks efficiently.
