1. Accessing Pabbly Connect for WhatsApp Campaigns
To create a WhatsApp broadcast campaign, you first need to access Pabbly Connect. This platform is essential for integrating various applications like Pabbly Chatbot and Google Sheets.
Begin by logging into your Pabbly account and navigating to the Pabbly Chatbot feature. Here, you can utilize the broadcasting tool to reach your audience effectively.
2. Creating a Broadcast Campaign Using Pabbly Chatbot
Once you are in Pabbly Chatbot, click on the “Add Broadcast” button to start your campaign. This step is crucial as it sets the foundation for your WhatsApp messaging.
  • Select the broadcast type as “Campaign Broadcast”.
  • Enter a name for your campaign, such as “Donation Awareness”.
  • Choose your target audience by selecting an existing contact list or uploading a CSV file.
After selecting your audience, you can refine it further by excluding contacts who have recently interacted. This ensures your messages reach the right people without redundancy.
3. Creating Your Message for the Broadcast
In this step, you will choose the type of message to send via Pabbly Connect. You can opt for a pre-approved template or a regular message based on your campaign needs.
To create a compelling message, select the WhatsApp template you want to use. For example, if you chose the “Donation Awareness” template, you can enhance it by adding images or other media elements.
  • Ensure that the template has been approved by Meta for use.
  • Test the message by sending a sample to a test contact.
After testing, you can finalize your message, ensuring it is visually appealing and informative for your audience.
4. Scheduling and Sending Your WhatsApp Campaign
With your message ready, it’s time to schedule the broadcast. This is where Pabbly Connect shines, allowing you to set a specific time for your campaign.
For example, if you want to send your message on November 10th at 4 PM, simply input this date and time in the scheduling section. You can also enable automatic retries for contacts that fail to receive the message.
Once you have set everything, click on the “Create Broadcast” button to finalize your campaign. This step is crucial as it activates the broadcast process.
5. Monitoring and Analyzing Campaign Results
After your campaign has been sent, you can monitor its performance using the statistics feature in Pabbly Connect. This allows you to see how many messages were delivered successfully.
To view the statistics, click on the “View Statistics” button. Here, you will find detailed insights into the effectiveness of your broadcast, enabling you to make improvements for future campaigns.
Utilizing these insights is essential for optimizing your future broadcasts and ensuring better engagement with your audience.
Creating a WhatsApp broadcast campaign using Pabbly Connect and Pabbly Chatbot is straightforward and effective. By following the steps outlined, you can seamlessly integrate CSV files and schedule your messages efficiently. This process enhances your communication strategy significantly.
