1. Setting Up Pabbly Connect for Your WhatsApp AI Assistant
To create an AI assistant for WhatsApp, the first step is to access Pabbly Connect. Start by opening a new tab and visiting pabbly.com/chatbot to create your free account. Once registered, you will receive 100 free credits each month, perfect for testing the platform.
After logging in, navigate to the Pabbly Chat Pro dashboard. Here, you will find various powerful features offered by Pabbly Connect. Click on the AI Assistant feature to begin creating your WhatsApp AI assistant.
2. Creating Your AI Assistant with Pabbly Connect
To create a new AI assistant, click on the “Add AI Assistant” button. You will need to give your assistant a descriptive name, such as “AI Assistant for Dental Clinic”. After naming it, click on the “Add AI Assistant” button again to proceed.
  • Choose the type of instruction as “AI Agent”.
  • Adjust the temperature setting to control the creativity of responses.
  • Select OpenAI as the AI model provider and choose the version.
These settings will help define how your AI assistant behaves and responds to queries. Make sure to customize these options based on your specific needs.
3. Integrating OpenAI with Pabbly Connect
Next, you need to connect your OpenAI account to the AI assistant. This is done by pasting your OpenAI API key into the designated field. To obtain your API key, navigate to the OpenAI API keys page and click on “Create New Secret Key”.
After generating the key, return to Pabbly Connect and paste it into the API key field. Click on the connect button, and you should see a success message confirming that your API key has been saved.
4. Customizing Your AI Assistant Responses
Once your AI assistant is connected to OpenAI, you can customize its responses. You can add a welcome message, a closing message, and set retry attempts for failed responses. An example of a welcome message could be, “I’m here to assist you at Smile Care Dental Clinic.”
  • Add keywords for stopping the assistant, like “stop”.
  • Set the number of retry attempts for failed responses.
  • Upload a knowledge base file to enhance responses.
This knowledge base is crucial as it allows your AI assistant to provide accurate and relevant answers to customer inquiries.
5. Finalizing Your AI Assistant Setup
After customizing your AI assistant, the final step is to activate it. Toggle the activation switch to make your AI assistant live. Then, click the “Save Assistant” button to finalize your setup.
Your AI assistant is now ready to assist customers on WhatsApp. You can also embed it into your website by clicking on the embed option to get the code snippet.
With Pabbly Connect, you can automate your WhatsApp business conversations effectively. This setup allows your AI assistant to work around the clock, providing support even when you are unavailable.
In conclusion, using Pabbly Connect to create an AI assistant for WhatsApp is a straightforward process. By following these steps, you can enhance customer interaction and automate responses effectively.
