To automate your customer return requests, start by accessing Pabbly Connect. Navigate to the Pabbly homepage and sign in, or create a new account for free. Once signed up, you’ll receive 100 free tasks each month to explore the platform’s capabilities.
After logging in, you can explore various Pabbly products, including Pabbly Subscription Billing and Pabbly Email Marketing. For this automation, we will primarily focus on using Pabbly Connect to integrate Google Forms and Google Chat for seamless customer support.
2. Creating the Automation Workflow in Pabbly Connect
Once you are in Pabbly Connect, click on the “Create Workflow” button. You will see options to create from scratch or use the quick builder. For this automation, select the quick builder option.
- Select Google Forms as the trigger application.
- Choose the trigger event as “New Response Received”.
- Select Google Chat as the action application.
- Choose the action event as “Create Message”.
After setting up these parameters, click on “Create”. This will generate a workflow that triggers every time a new response is submitted in Google Forms, allowing Pabbly Connect to handle the data flow seamlessly.
3. Connecting Google Forms to Pabbly Connect
To connect Google Forms with Pabbly Connect, copy the webhook URL provided in your workflow. Then, go to your Google Form and link it to a Google Sheet. This is crucial as it allows the responses to be captured automatically.
- In Google Forms, navigate to “Responses” and click on the green Sheets icon.
- Create a new spreadsheet to store responses.
- Use the “Pabbly Connect Webhooks” add-on to link the Google Sheet back to Pabbly Connect.
Once the Google Sheet is set up, you can send a test response from your form. This will create a new row in the sheet and allow Pabbly Connect to capture this data for further processing.
4. Sending Notifications via Google Chat
With your Google Forms connected to Pabbly Connect, the next step involves setting up notifications through Google Chat. You will need to create a webhook URL in your Google Chat space to send messages.
- Open Google Chat and navigate to the space where you want to send notifications.
- Click on the space name, select “Apps & Integrations”, then click “Add Webhook”.
- Name your webhook (e.g., “New Return Request”) and copy the generated URL.
Paste this URL back in Pabbly Connect and customize the message to include relevant details from the form submission. This ensures that your team receives timely updates on return requests.
5. Sending Acknowledgement Emails to Customers
Finally, set up an automated response for customers using Pabbly Email Marketing. Select Gmail as your action application in the Pabbly Connect workflow.
- Map the recipient email address to the customer’s email from the form response.
- Set the email subject as “We have received your return request”.
- Customize the email body to acknowledge the request and assure them of a follow-up.
Once this is configured, every time a return request is submitted, your customers will automatically receive an acknowledgment email, enhancing their experience and satisfaction.
In this tutorial, we demonstrated how to use Pabbly Connect to automate customer return requests effectively. By integrating Google Forms and Google Chat, businesses can streamline their customer service processes and improve overall efficiency.
