To start integrating TikTok leads into your HubSpot CRM, the first step is to access Pabbly Connect. Open your browser and navigate to www.pabbly.com/connect. If you’re a new user, sign up for free to receive 100 tasks each month, allowing you to test the integration.
Once logged in, you can create your automation setup. Pabbly Connect simplifies the process of connecting different applications without any coding skills. For this tutorial, we will set up a workflow that captures TikTok leads and automatically adds them to HubSpot CRM.
2. Creating the Connection with TikTok Lead Generation
The next step is to create a connection with TikTok Lead Generation through Pabbly Connect. In your dashboard, click on the “Connect” option and select “TikTok Lead Generation” as your trigger application. You will then need to authorize the connection.
- Click on “Add New Connection” and then select “Connect with TikTok Lead Generation”.
- Grant permission by clicking the “Confirm” button.
- Choose the advertisement ID and form ID from your TikTok account.
After connecting, generate a test lead to ensure that the integration works correctly. This test lead will be captured by Pabbly Connect and used in the next steps for mapping data into HubSpot.
3. Mapping Data to HubSpot CRM
Now that the test lead is captured, the next step is to map this data to your HubSpot CRM using Pabbly Connect. Add an action step and select “HubSpot CRM” as the action application. Click on “Connect” to establish a connection.
In the connection window, select your HubSpot account. You will then be prompted to fill in the details for the contact you want to create. The most important field is the email address, which you will map from the previous step.
- Map the email address from the TikTok lead response.
- Fill in other fields like first name and last name, which may require additional steps to split the name.
- Set the lead status and timezone as needed.
Once all required fields are filled, click “Save and Send Test Request”. If successful, you will see a confirmation that a new contact has been added to HubSpot.
4. Testing the Integration Workflow
After mapping the data, it’s crucial to test the integration workflow using Pabbly Connect. Ensure that the test lead you generated appears in your HubSpot CRM. This step verifies that the connection between TikTok and HubSpot is functioning correctly.
To test, refresh your HubSpot contacts page. You should see the new contact created from the test lead. This confirms that the integration is successful and that any new leads from TikTok will automatically sync to your CRM.
Additionally, you can monitor the workflow in Pabbly Connect to ensure that all leads are captured in real-time. This automation saves valuable time and allows your team to focus on lead management without manual entry.
5. Finalizing the Setup for Future Leads
Now that the integration is tested and working, you can finalize the setup in Pabbly Connect. Make sure to remove any unnecessary test leads from your workflow to keep it clean and efficient.
With the integration complete, every new lead generated from your TikTok ads will automatically be added to your HubSpot CRM. This seamless process ensures that you never miss a potential client and can manage your leads effectively.
By utilizing Pabbly Connect, you can create multiple automations for other applications as well, enhancing your overall business efficiency.
In this tutorial, we demonstrated how to integrate TikTok leads with HubSpot CRM using Pabbly Connect. This automation streamlines your lead management process, ensuring that every lead is captured and organized effectively.
