1. Accessing Pabbly Connect for Integrations
To begin using Pabbly Connect, navigate to the landing page by entering ‘pabbly.com/connect’ in your browser. This platform serves as the central hub for integrating various applications, including Facebook Lead Ads and Google Sheets.
If you’re a new user, click on the ‘Sign up for free’ button. You will receive 100 free tasks each month to explore the features of Pabbly Connect. Existing users can simply sign in to access their dashboards.
Once logged in, click on the blue ‘Create Workflow’ button to initiate a new integration. Pabbly Connect allows you to easily set up workflows that automate the process of capturing leads.
  • Select the applications you want to connect, starting with Facebook Lead Ads.
  • Choose the trigger event, which in this case is ‘New Lead’.
  • For Google Sheets, select ‘Add Row’ as the action event.
After setting up the basic parameters, click on ‘Approve and Create’. This will prepare your workflow for capturing leads from Facebook into Google Sheets.
To connect Facebook Lead Ads, you’ll need to establish a connection between your Facebook account and Pabbly Connect. Click on the ‘Connect’ button next to Facebook Lead Ads.
If you are creating a new connection, select ‘Add New Connection’. Log in to your Facebook account and authorize Pabbly Connect to access your lead ads. Choose the Facebook page that is running your ad campaigns.
4. Mapping Data to Google Sheets
After successfully connecting Facebook Lead Ads, navigate to Google Sheets and click on ‘Connect’. Choose the spreadsheet where you want to store the leads data.
In the mapping section, you will map the fields from Facebook Lead Ads to your Google Sheets. For instance, map the lead’s name, email, and contact time. This ensures that every new lead captured automatically populates the spreadsheet.
  • Select the spreadsheet name and the specific sheet where data will be stored.
  • Insert dynamic fields using the previous response from Facebook Lead Ads.
Once mapping is complete, click on ‘Save and Send Test Request’ to verify that data is being captured correctly.
5. Conclusion
In this tutorial, we demonstrated how to integrate Facebook Lead Ads with Google Sheets using Pabbly Connect. By following these steps, you can capture leads efficiently and store them in one place, enhancing your lead management process.
Utilizing Pabbly Connect for this integration simplifies the workflow, allowing you to focus on growing your business without manual data entry.
