To start using Pabbly Connect for integrating Facebook Lead Ads with WhatsApp, first, visit the Pabbly Connect dashboard. You can access it by typing pabbly.com/connect into your browser’s URL bar. Once there, you’ll see options to sign in or sign up.
If you are a new user, click on “Sign Up Free” to create an account. As a new user, you will receive 100 free tasks each month to explore Pabbly Connect. If you already have an account, simply sign in. This setup allows you to automate lead capturing and messaging effectively.
Once signed in to Pabbly Connect, click on the “Create Workflow” button. This action will direct you to a new workflow builder. Here, you can use the quick builder feature, which simplifies the process of selecting trigger and action applications.
- Enter the prompt: “Integrate Facebook Lead Ads with WhatsApp”.
- Select the trigger as “New Lead” from Facebook Lead Ads.
- Choose WhatsApp Cloud API for the action application.
- Set the action to “Send Text Message”.
After entering these details, click on “Approve” to finalize the setup. This process will create a seamless workflow that connects Facebook Lead Ads to WhatsApp through Pabbly Connect.
In this step, you need to establish a connection between Facebook Lead Ads and Pabbly Connect. Click on the Facebook Lead Ads option in your workflow and select “Add New Connection”. This action will prompt you to log in to your Facebook account.
After logging in, select the Facebook page you want to use for lead capturing. Here, you can choose your form, such as “New Leads”, to receive the leads directly. Ensure that the response format is set to simple. Click on “Save and Send Test Request” to confirm the connection.
4. Setting Up WhatsApp API in Pabbly Connect
Now, it’s time to configure the WhatsApp Cloud API within Pabbly Connect. You will need to input your WhatsApp Cloud API Token, Phone Number ID, and WhatsApp Business Account ID. To find these details, refer to the WhatsApp Cloud API documentation.
Once you have these details, return to Pabbly Connect and paste them into the respective fields. After entering the information, click on “Save” to establish the connection. This setup will allow you to send messages via WhatsApp whenever a new lead is captured from Facebook.
- Enter your WhatsApp Cloud API Token.
- Provide your Phone Number ID and WhatsApp Business Account ID.
- Click “Save” to finalize the connection.
This configuration ensures that every new lead will receive an automated WhatsApp message, enhancing your engagement efforts.
5. Mapping Data and Testing the Integration
With everything set up, it’s essential to map the data from Facebook Lead Ads to WhatsApp. In the WhatsApp API settings, map the recipient’s mobile number to the phone number received from the Facebook lead. This dynamic mapping ensures that the correct number is used for each new lead.
Next, enter the message you want to send. You can personalize the message by mapping the lead’s first and last name. After setting up the message, click on “Save and Send Test Request” to confirm that everything works smoothly. You should see a success message indicating that the WhatsApp message was sent successfully.
Finally, check your WhatsApp to confirm receipt of the message. This step verifies that the integration between Facebook Lead Ads and WhatsApp via Pabbly Connect is functioning correctly, allowing for seamless communication with your leads.
In this tutorial, we demonstrated how to automate lead capturing from Facebook Lead Ads and send WhatsApp messages using Pabbly Connect. By following the steps outlined, you can enhance your business communication and engagement with leads efficiently.
