1. Setting Up Pabbly Connect for Instagram Leads
To capture Instagram leads directly in Zoho CRM, you’ll first need to set up Pabbly Connect. Begin by signing into your Pabbly account and navigating to the dashboard.
Next, click on “Create Workflow” and select “Create from Scratch.” Name your workflow as “Capture Instagram Leads Directly in Zoho CRM” and select the appropriate folder. This process enables you to automate lead management effectively.
2. Triggering Instagram Lead Ads in Pabbly Connect
In this step, we will set Instagram Lead Ads as the trigger application in Pabbly Connect. Choose “Instagram Lead Ads” as your trigger application and select “New Lead Instant” as the trigger event. This setup ensures that every new lead generated from your Instagram ads will initiate the workflow.
To connect your Instagram account, click on “Connect” and follow the prompts to authorize Pabbly Connect. Ensure your Instagram account is linked to your Facebook account for a smooth connection. Once connected, you will need to specify the page and lead gen form.
- Select the page (e.g., Digital Dynamics).
- Enter the lead gen form associated with your ads.
After entering these details, click on “Save and Send Test Request” to check if the connection works correctly. This will set the stage for capturing leads efficiently.
3. Testing the Webhook Response in Pabbly Connect
Now that we have set up the trigger, it’s time to test the webhook response in Pabbly Connect. This step is crucial for ensuring that the integration captures leads successfully. To do this, use the lead ads testing tool provided by Facebook.
Generate a lead by filling out the lead form with test data. After submitting, return to your Pabbly Connect dashboard to see if the webhook response appears. If successful, you will see the details of the new lead, confirming that the connection is working as intended.
- Ensure you delete any previous test leads before submitting a new one.
- Check that the lead details match what you submitted in the form.
This verification step is essential for the next phase of the integration.
4. Setting Up Zoho CRM as the Action Application
Next, we will set Zoho CRM as the action application in Pabbly Connect. Search for “Zoho CRM” and select “Insert Update Record with Subform Data” as the action event. This step allows you to automate the addition of new leads into your CRM.
When prompted, connect your Zoho CRM account by entering the correct domain (e.g., zoho.in). Once connected, you will need to specify the module type for the new lead, such as “Contact” or “Lead.” Make sure to map the fields from Instagram Lead Ads to the corresponding fields in Zoho CRM for accurate data transfer.
- Map the first name and last name fields from the Instagram lead data.
- Ensure all relevant fields are mapped to avoid data loss.
After mapping the fields, click on “Save and Send Test Request” to confirm that the data is being sent correctly to Zoho CRM.
5. Verifying Data in Zoho CRM
The final step is to verify that the data captured from Instagram leads is correctly populated in Zoho CRM. After sending the test request, navigate to your Zoho CRM and refresh the contacts page.
Check for the newly created contact with the details submitted through the lead form. If the integration is successful, you will see the lead’s information accurately reflected in your CRM. This confirms that Pabbly Connect has effectively linked Instagram Lead Ads with Zoho CRM.
By following these steps, you can automate the lead capturing process, saving valuable time and reducing manual entry errors. This integration not only streamlines your workflow but also enhances your ability to manage leads efficiently.
In this tutorial, we explored how to capture Instagram leads directly in Zoho CRM using Pabbly Connect. By automating this process, you can save time and improve lead management efficiency.
